Which Combustion Analyzer?
Please recommend your favorite combustion analyzer regardless of whether or not it uses Bluetooth or other wireless technology.
Many thanks!
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes
Look at e-instruments 1500 or 4500. I have seen the 4500. The tech had nothing but good things to say about it. I have a testo 330. I would trade it for a 4500.0
I have the 320 and after several issues with getting it back not working I broke down and brought a new Testo 300LL. Its so much better than the 320. Ability to save customer info and test results, as well as email them. WiFi, bluetooth and 5 year sensor lifespan and warranty. Just make sure to get the printer, its a bluetooth one and not the same as the one the 320 uses. But it looks exactly the same way.0
E Instruments. I’ve had mine for about 12 years and the only thing I’ve had to do is replace the O2 sensor like on any other.
They’re located near Philly.Bob Boan
Testo 300 Pro.
Touchscreen. Easy to use. It’s an android phone.
Can connect to wifi/personal hotspot from your phone. Can email directly from the analyzer. Can Bluetooth combustion reports to your phone or computer right from the analyzer.
I buy them for my techs from Roger Downey at Highmark Analytics in Hardwick, NJ. When it’s time to calibrate them Highmark will send you a free spare to use while you send yours to them for calibration.Never stop learning.2 -
I have a Bacharach Fyrerite which is ok with the QR scanner to get the report into a PDF using my phone or tablet. I often find if I need to add more notes in the comment section I need to use my laptop with PDF editor. I started to use the Quick Measure app with my wireless refrigerant gauges and noticed that the app is more user friendly with Testo, Fieldpiece, and other manufactures vs my Bacharach. I have been checking out Wohler combustion testers as well to maybe ditch the Bacharach, but a pro press seems to be next on my tool list.
Owner of Grunaire Climate Solutions. Check us out under the locate a contractor section. Located in Detroit area.
I like the Bacharach Insight Plus. With the QR code, you can email the combustion report. But what I did was make my own app with FileMaker. I can scan the QR code and put the results right into my database too.
Plus it has a feature (Tune Right?) that can help with diagnosing combustion issues.
And it has a printer.There was an error rendering this rich post.
We're using Wöhler (which, according to my German-speaking customers, is pronounced "Voo-lar") A400 units. These pre-date Bluetooth connectivity though, but have been very reliable. Wöhler's current lineup is here:
https://www.wohlerusa.com/shop/products/measuring-instruments/combustion-analyzers/
I don't mind sending these units out for maintenance. The service people send a calibration certificate back with the unit, which we keep on file in case there is an issue down the road and some lawyer tries to shake us down. We have one for each truck, and a spare for when one goes in for service.All Steamed Up, Inc.
Consulting1 -
I'm sorry about your loss, @JohnNY but on the bright side you don't have to have it recalibrated
I hear you, but given the price, you could buy two and still be ahead of the game. I do love it other than that.BillyO said:bought a TPI, loved it, until I had to send entire unit to Oregon to have it calibrated
-1 -
I'm looking at the Testo website. Why isn't the Testo 310, at half the price of the others, more popular?Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Classes0 -
From from what I’ve read, sensor lifetime of 310 is rather limited and expensive to replace. Have to send in for replacement I believe at $400-500.The 320 module is about $150 and can be replaced by tech. Of course calibration check would be required.0
That’s good point, take a look at the cost on the site below. What’s the life of the sensor before OEM replacement required?Robert O'Brien said:bought a TPI, loved it, until I had to send entire unit to Oregon to have it calibrated
Anyone have experience with Fieldpiece SOX3? They do call them combustion check meter and not combustion analyzer. Some comments about them not being able to check co parts per million. It does measure co2 o2 etc so you would be able to adjust boiler to make it efficient which is the whole point of a combustion analyzer. They also seem to not need to be calibrated and have replaceable o2 sensor. Any advice is greatly appreciated.0
@danitheplumber
There was another thread on this a while back. If you can't measure Co it doesn't do much good. That's the consensus4 -
I purchased the TPI 610 Combustion Gas Analyzer this week and have found it very easy to use. The unit does not have a display but connects to your smart phone via Bluetooth. I attached a screen capture below of screen during start of low fire test. Very easy to generate and email reports
I bought from TruTech tool (link above), the price was $405 before tax. The unit arrived in a couple days with a calibration cert from mid October of this year, nice!
The TPI 610 has user replaceable CO2 and CO sensors; the sensor are warrantied for two year.
I talked with a TPI tech re calibration and sensor replacement; calibration alone is around $60; calibration with new sensors is approx. $200. He said the sensors are user replaceable but typically people send the entire unit back so it can be recalibrated at same time.
I think you mean the 710. The 610 is a manometer. I have the same analyzer too - I've been happy with it - I like the idea if it being BT and using your phone as the screen.PC7060 said:
Global Test Supply has it for the same price, and you can usually a 5 or 10% off coupon which makes it pretty reasonable.
John, I think my least hated analyzer has been the UEI. Testo, too many repairs to count. Have not had the latest Bacharach but not sure I want to go there. Uei can come with long life cells. We use the C165 kits.
Good Luck
Tim0 -
John, the UEI C165BTKIT has blue tooth. Decent analyzers.0
