Boiler issues
Nicoletitti
Member Posts: 2
I am having issues getting my Utica Mgb series biker to ignite. Replaced the thermocouple today. The pilot stays lit, can hear the thermostat click and then nothing. Any ideas for a very green repair woman with two young kids who is freezing?
Do you have just one thermostat? Does your boiler also make hot water for your showers? Oil or gas? Pictures of the boiler might help.0
If a standing pilot with thermocouple, perhaps no ignition control module.
Pictures needed.0 -
If a standing pilot with thermocouple, perhaps no ignition control module.If it's an older model, you may be right.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
If it is a standing pilot, with a Basso control, I have noticed that the sheet metal cover can bind with the button, preventing the button from popping out completely as you light the pilot.
I replace the thermocouple a couple of times before I figured that one out!—NBC0 -
Pictures??0
Sorry everyone. Turned out that after replacing the aquastat next the burner is bad. New heater installation tomorrow0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
