Hole in Steam Pipe
Nick_37
Member Posts: 38
This is a strange one. Our steam pipe started leaking a few hours ago. Further investigation found that the cause of the leak looks to be a drilled hole in the pipe. It must have been sealed a very, very long time ago and has finally rusted through. Pretty sure this is the original piping and we have looked after our steam system with the help of this forum and Dan's books. My question is whether I need to have a plug installed by a professional or I can just use J-B Weld? The steam pipe is 2.5 inch pipe so the hole is pretty small. Welcome the thoughts of the steam pro's on this site.
I already have a clamp to seal it for Thanksgiving. Just need advice on the right way to repair the hole. It’s definitely been drilled and plugged at some point in its history. The seal held out for a very long time. We been in the house for 12 years and it’s not been an issue.0
It is hard to tell if pipe was threaded to accept a previous plug. If it is, buy another one and screw it in. If it isn't, any of the above suggestions would work for another 12 years.0
It’s not currently threaded and it’s open in our basement living space hence the white paint. The hole is slightly smaller than a 1/4 inch drill bit which is why I figured the JB Weld would work given the size. Pipe looks in good shape otherwise.0
Put a pipe clamp on it. If it measures 2.5" outside diameter it is a 2" steel pipe. Here's one from Home Depot;
https://homedepot.com/p/Eastman-2-in-IPS-Stainless-Steel-Pipe-Repair-Clamp-45198/313715749?MERCH=REC-_-pipsem-_-313715687-_-313715749-_-N&1 -
i have 2 holes on my steam pipe bought High Temp pipe Repair kits from home depot $12 each, and patch it them, it's been 2 years, and no issues.0
For a quick temporary fix, I've used https://cleanfit.com/blue-monster-compression-seal-tape.shtml in the past. It held back live steam for over a year before I got around to making a permanent repair.0
What did you do for the permanent repair?0
What's wrong with my suggestion?
Nothing @ChrisJ 😉. I’m wondering if it was a main vent attempt, or a pin hole repair attempt...if the latter, somethings awry.1
I silver-soldered the hole shut. I couldn't have drilled & tapped it, there wasn't enough meat left to do that.
I imagine that the silver solder is technically another temporary repair, but it's lasted three or four years now with no sign of imminent failure, so I'm going to keep on keeping on as long as I can.
It is already a nice round hole... I may be biased being a machinist, but it would be almost criminal to not just drill/tap for a 1/8 NPT plug and be done with it forever. 1/8 NPT works because if the hole is indeed already around 1/4” diameter, it needs oversized only a bit more for the proper 1/8NPT tap drill size.1
The JB weld will work just fine if you clean the pipe well.
Before you use the JB weld push a small wad of toilet paper into the hole. This will prevent the JB weld from being squeezed into the steam main,
I like the JB weld that you mix the epoxy and hardner together.
JakeSteam: The Perfect Fluid for Heating and Some of the Problems
by Jacob (Jake) Myron0
