C.I. Radiator Height Adjustment
hvacfreak2
Member Posts: 500
Hey Guys , I was wondering what is the best way to trim 1/4 inch from the legs of a small ci radiator ? I am thinking an angle grinder or a small band saw will work but just wanted some feedback from someone who has done this. The legs are not really fancy , just 3/8 square posts for my best description. Thanks for replies.
hvacfreak
Mechanical Enthusiast
Burnham MST 396 , 60 oz gauge , Tigerloop , Firomatic Check Valve , Mcdonnell Miller 67 lwco , Danfoss RA2k TRV's
Easyio FG20 Controller
Access to the piping is the main reason I am looking at trimming the radiator feet. And thinking about it now I don't care for the shape of the legs on the bottom so I'll kill 2 birds / 1 stone and use the grinder.hvacfreak
Burnham MST 396 , 60 oz gauge , Tigerloop , Firomatic Check Valve , Mcdonnell Miller 67 lwco , Danfoss RA2k TRV'sEasyio FG20 Controller
I'd rather remove some of my floor than grind off my radiators' feet
See my sight glass boiler videos: https://bit.ly/3sZW1el3 -
There is a casing line about 1/4 inch up from the bottom ( where I would like to be ). But above that line all bets are off looking at it now. I'm going to go to the line and see what happens. I'll go with Baseray or a fabricate a pipe radiator if this doesn't work out. It's not a Victorian lions claw or anything , just a basic 3 tube water style. Changing any piping on this is just not an option.hvacfreak
I would guess the legs are solid but who knows? And it's the kind of thing that could vary from leg-leg and manufacturer-manufacturer0
A thin cutoff wheel on a 4" angle grinder would be my tool of choice. May be easier than grinding away all the metal.Bob "hot rod" Rohr
I ended up using a heavy wheel . It's almost like the feet had solid metal " pads " on the bottom for this purpose . I removed what I needed to with no problems. Being careful is the same as being wise , but some folks freak the f out when mentioning such things as grinding some cast iron. SMH , I guess nervous folks don't break anything ( or win races ) for sure.
hvacfreak
I don't think you need to affect that mocking tone. You asked people's opinions, and responsible people are cautious to give advice that if followed could cause your radiator to be ruined. Next time feel free to saw anything you want without asking.
Being caution and calculating is how the often win races.... and how you run profitable businesses.
Doing something once carefully and taking 30 minutes is faster than rushing and doing it the first time in 25 and the second time in another 35.... because you really don’t want to do it a 3rd time.0 -
Don GarlitsJamie Hall said:There are old pilots. There are bold pilots. There are no old, bold pilots...
https://en.wikipedia.org/wiki/Don_Garlits
But yeah I'm going to admit when I was finished I was sorry I even brought it up.
hvacfreak
1
