Oil-Gas replacement conversion
On that old boiler the low water cutoff was clogged solid and the rear bottom drain only trickled water out, so it took time to drain it. When I pulled the fire box door off the combustion chamber had at least 4-5” of soot and carbon on the floor. The burner was a brand new Carlin and you see the head starting to warp from the heat. The oil company kept great records of all their yearly services though lol. In fact the last PM was October 2019. Unbelievable!!!
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......
Nice looking job, @Dave0176 ! But one does sort of have to wonder about the previous service, eh?Br. Jamie, osb
no old pictures?0
Just the one, it’s was too dirty once we started pulling it apart.jerryb46 said:no old pictures?
DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
I cannot force people to spend money, I can only suggest how to spend it wisely.......0 -
Real clean install @Dave0176 ! Lots of room to work on this one for once, right?
What did you have to dig out of the floor?NJ Steam Homeowner.
Oil lines.
Beautiful job! Too bad it's not still oil fired though.
Was that a Winkler? I can almost read it.1 -
Yes it was a Winkler a three section pretty damn heavy too. In all my years of doing this job I’ve never come across a Winkler.HVACNUT said:> @ethicalpaul said:
Oil lines.
Was that a Winkler? I can almost read it.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
As @HVACNUT said we dug up the oil lines, tank company is there today pulling the tank.ethicalpaul said:Real clean install @Dave0176 ! Lots of room to work on this one for once, right?
And Paul actually the room was very small where they had the boiler only 6X8 so truthfully it was tight especially with all my tools and my pop in the same room.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
I cannot force people to spend money, I can only suggest how to spend it wisely.......1 -
We see it all the time Jamie especially on the older boilers because it requires more work to remove the burner and fire box door.Jamie Hall said:Nice looking job, @Dave0176 ! But one does sort of have to wonder about the previous service, eh?
And if anyone asks, no I still don’t own a propress I still sweat all my copper. Maybe someday.
A lot of old boilers that get thrown away because lazy technicians won't take down the smoke pipe and clean it and combustion chambers full of soot. Not saying that was the case here0
Thanks! Why is it too bad that it's not still oil fired? That sweet oil smell, the high cost, or the loud blower noise?HVACNUT said:> @ethicalpaul said:
Oil lines.
Was that a Winkler? I can almost read it.NJ Steam Homeowner.
Oh wow, the picture was deceiving! The install is just so beautiful and simple even with the twin supplies and drop header.NJ Steam Homeowner.
I haven't done anywhere near as much soldering as anyone on this page. But I do really enjoy sweating copper fittings, its always quite satisfying to melt the solder around the joints and then know that the joint isn't going anywhere.Dave0176 said:And if anyone asks, no I still don’t own a propress I still sweat all my copper. Maybe someday.
Located in durham NC.
> @luketheplumber said:
> (Quote)
Its very satisfying until you have a problem. Leaky sweat joints are a real pain. Try to remember that keeping the fittings super clean and make sure everything is straight and level. Avoid trying to solder any pipe with water in it. If you have a valve that doesn't close fully and you can't keep water out of the pipe there's a product called a Jet Sweat that will seal the inside of the pipe and keep the water out.
Or you can use an old trick....stuff a piece of bread down the pipe and it will soak up the water so you can solder. Flush it out through the tub or a spigot without a strainer when you are done.1 -
- 87K THE MAIN WALL
- 112 Chimneys & Flues
- 106 Geothermal
- 979 Plumbing
- 387 Solar
