Imagine That
New England SteamWorks
Member Posts: 1,529
They installed the new boiler and suddenly a condensate tank was required to return the condensate.
I wonder why....
I wonder why....
newenglandsteamworks.com
3
Nice blocks.....cheaper than extending risers!
Maybe they didn't want the flood water to fill the boiler!!!0
You’d think the pit would have caused them to contemplate a bit...New England SteamWorks
newenglandsteamworks.com1 -
I notice the p'trols aren't protected from steam. Wonder which one will fail first.Just another DIYer | King of Prussia, PA
People often say that, but...Hap_Hazzard said:I notice the p'trols aren't protected from steam. Wonder which one will fail first.
How can steam get to them?Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
New boiler and kept the ancient burner?
How can steam get to them?Just another DIYer | King of Prussia, PA
> @Hap_Hazzard said:
> (Quote)
> Convection.
Steam doesn't fill voids via convection.
I'm betting the Ptrols on the ends will stay cold. The one in the center not sure about, it's kind of close.
My own boiler has two sets of controls, the ones I actually use and care about do not have a pigtail or trap of any kind. Just 18" of vertical pipe with air trapped in it. It gets hot maybe a few inches up and that's it. Most of the 1/2" black iron pipe stays room tempSingle pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
i guess that is one way to raise the water line...0
Really? I seem to recall a few weeks ago people were trying to convince me that my dry return was filling with steam even though it's full of air and pitched downwards, so, apparently, steam can overcome gravity AND an air-filled void to travel some 20 or 30 feet downhill back to the boiler, but it can't rise a few inches to reach the pressuretrol? Fascinating.ChrisJ said:
Steam doesn't fill voids via convection.Just another DIYer | King of Prussia, PA
I meant back in the day when it was initially installed. It’s not new any longer.
I am sure the condensate tank wasn’t in the bid.New England SteamWorks
Steam doesn't fill voids via convection.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Was the old boiler an old coal unit with a very large steam chest with a very large water content that steamed much slower than the newer boiler?0
I also like that jacked up 67.... and no blow down for the lower piping to keep it clear.To learn more about this professional, click here to visit their ad in Find A Contractor.0
- 116 Geothermal
- 15.8K Strictly Steam
