Gyroscopic Balance Gas Conversion Burner- Tim are you there??
Adam_13
Member Posts: 49
in Gas Heating
Hey Tim this is Adam in New Britain, CT. Years ago you helped me with service manuals for the Gyroscopic Balance gas conversion burners by the Autogas corp. I always wanted to restore the boiler and burner, but I'm selling the house. Are you still interested in the burner?? I have everything except the hood for the smoke pipe. Even have the original t-stat. Message if you're interested, it'll need to be picked up in New Britain. Hope all's well-Adam
Aww too bad!! I understand though.
Wishing all the best, -Adam0 -
is that control wiring laced?0
What do you mean laced?0
Many, many years ago a lot of the commercial or industrial jobs that I saw and serviced had control wiring laced with "waxed string". It looked great and made a beautiful job that everyone would be in awe of. Later, the waxed string was replaced with a spiral plastic covering probably due to the strings high cost to install. The string lacing reminded me of my time in the navy when almost every cold pipe such as hand rails and the like were wrapped with rope, string or whatever probably to give guys something to do and keep them "out of trouble". The problem came when someone had to change a control that was no longer made and the wiring had to be moved to adapt the new device. That is when the swearing began. Most of this lacing that I saw, if memory serves me right, was done on Auburn Gas, Metler and S T Johnson Rotary burners, utilizing Honeywell R478A or B primary controls but could have been done on other burners as well.1
Lacing was common in complex low energy wiring like AV systems in to the 80's. We had a system that was built in 1985 and mostly untouched until it was replaced about 10 years ago that was all laced and all the installed non-video wiring was punched down to telephone style blocks then connected with jumpers from the block to the equipment in the rack.0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 106 Geothermal
- 983 Plumbing
- 389 Solar
