Big mouth bad after 1 month
tlowc34
tlowc34 Member Posts: 75
https://youtu.be/ZSTeZo0xMM4
Boilertrol Cut in set to .5psi, diff set to .5psi
It was throwing steam to the floor boards added nipple and elbow to direct it downward.
@Jamie Hall I guess I found my water loss.
What the heck dudes?!
    ethicalpaul Member Posts: 8,051
    edited January 2020
    that pipe isn’t doing much. Take the leaker out of service. I did too. And others
  • tlowc34
    It’s directing condensate to the floor!
  • tlowc34
    @ethicalpaul go to a different vent? I’m shocked, I thought these things were the new hotness
  • STEAM DOCTOR
    STEAM DOCTOR Member Posts: 2,502
    Was it leaking from day one or did it start leaking after a month?
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,577
    They have a good guarantee, so contact the factory, for a replacement. They did have a bad batch, but will stand behind their product.—NBC
  • tlowc34
    Working great when I installed it in December. My worry is that the other 4 I installed are going to head south as well.
  • ChrisJ
    ChrisJ Member Posts: 17,046
    There's no reason to worry.
    They had a bad run of parts that are easily replaceable and they will stand behind. It's not a bad design.
    Just keep an eye on the others or talk to the manufacturer and ask them how to proceed. They may want to swap them before they fail.
    edited January 2020
    Even when mine does seal, it takes a long time, puffing more steam than I want to release each cycle. I love the solidness of it and the design, but in practice it's just not great in my opinion.
    And ironically due to its amazing flow capacity, it will throw a LOT of steam at your ceiling when/if it fails.
    And I believe there has been more than one bad batch.
    But to clarify, I wasn't say throw away your Big Mouths. I was saying take that leaking one out of service. You don't want that steam humidifying your ceiling like that and you don't want to waste all your steam into your basement.
    edit: one thing that comes to mind...maybe my system is too small for it. It might require a certain steam production to close faster, I don't know.
  • Gsmith
    Gsmith Member Posts: 442
    I will say that I had one out of two fail on installation about two years ago. The company was very responsive to replace the one that failed, and both have worked flawlessly so far....but, these large numbers of reported failures create a lot of extra work for installers and homeowners and I would hope that the manufacturer is taking aggressive steps to improve manufacturing quality control to avoid this. Hoping some one from Barnes and Jones reads this thread.
    SeanBeans
  • SeanBeans
    SeanBeans Member Posts: 525
    I don’t see me buying any big mouths with the amount of people coming on here saying they’ve had problems.
  • ChrisJ
    Well, with the amount of people also complaining about Gorton's I don't know what you're going to do. Hoffman?
  • tlowc34
    10,000 MoMs lined up? Lol - it would be pretty!
    ChrisJ
  • Hap_Hazzard
    Hap_Hazzard Member Posts: 2,917
    Maid O' Mist. Everybody LOVES them! :D
    Well MoM sells a #1 main vent that is the same capacity as the Gorton and it's way cheaper. I'm running one of each side by side, but go ahead and laugh everybody haha
    :wink:
    Hap_HazzardBobC
  • KC_Jones
    KC_Jones Member Posts: 5,902
    :wink:
    I don't know how the rest of you grew up, but I will never disrespect mom.
    2014 Weil Mclain EG-40
  • tlowc34
    I meant no disrespect to MoM, I was thinking of the look of a bunch of #4s on a long manifold. My lol was the work involved.
  • Hap_Hazzard
    Nobody'd better disrespect Mom!
    tlowc34
  • ChrisJ
    No,
    But Maid O Mist sucks............
    :p
  • tlowc34
    The views aren't bad though
    https://www.youtube.com/watch?v=bTV_q3cGe5Y
    ChrisJ
