Favorite hydronic quotes
"**** it, we're not building a liquor store here!" - rowdy old plumber I used to work with0
Looks OK from my house!All Steamed Up, Inc.
Consulting2 -
Thank you friend , one more time the legacy of great Carlson has taken attention of us to consider his thoughts and the way he stated Hydronics phenomenons . I wish that God keep all of the passing guys of this industry as His own .
Hope that this new year is filled with much more joy , happiness , health , prosperity and peace for you all .
your loyal friend,
Roohollah,1 -
"Once the nail is driven, the hammer just makes noise."
-John Cataneo
Used repeatedly to let my guys know they can stop complaining, making it tighter, oversizing boilers and water heaters, adding air vents, etc.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes1 -
Position is everything in Life.....
Mr HartyThere was an error rendering this rich post.
What ever could go wrong ,will go wrong ...
Murphy LawThere was an error rendering this rich post.
I can supply you with three things , Quality , Time and Price . Pick two !
Tark machinistThere was an error rendering this rich post.
When you’re going through hell, keep on going.
Yours, Larry0 -
Larry, have you read this book? Great stories about rust and corrosion, from beer cans to the Alaskan pipeline, well researched.Larry Weingarten said:Well, There is the old saying from the corrosion engineers, “Rust never sleeps.” They also named him... Demon Rust!
Yours, Larry
“You are not judged by your effort, only by the results”
Same boss0 -
Hi @hot_rod and @DanHolohan , I've got the book coming
It seems the iron age began around 1200BC, so this "Longest War" has been going on around 3200 years! Wonder who's winning?
"And the rest is rust and stardust", Vladimir Nabokov (a hydronicist in his own way)
Yours, Larry0 -
Ahh, Vladimir.Retired and loving it.0
-"Don't assume it ever worked right"
-"Gravity don't go uphill"
-"TLC= Total Lack of Concern"
-"Don't worry, they will call when they are hot (or cold)"- facility technician
-"Gotta remember, its been this way for 25 years!" (when its obviously poorly installed)- plant manager0 -
"if it aint broke, ya cant fix it...but you sure can screw it up"0
I recognize that one...lchmb said:"if it aint broke, ya cant fix it...but you sure can screw it up"
Show me a person that doesn't make any mistakes and I'll show you a person that doesn't do any work. Just make em small and don't make the same one twice.0
I Hate to Heat and Run, But I have other cold customers. can you write a check for $ X00.00?
and the oil fire "boiler" where you spilled a little oil during the service call... If the odor powder is not enough and you still smell oil tomorrow, Vinegar will cut an oil odor. "Wait for it..."
....and if you add a clove of garlic and some anchovies, your home will smell like a Cesar Salad.
"ouch!"
for those non-Italians that need an explanation
vinegar, oil anchovies & garlic are ingredents in a Cesar SaladEdward Young Retired
From Floyd Tinkham, one of the old timers I apprenticed under "PLAN YOUR WORK AND WORK YOUR PLAN"0
"The other guy said it was ok to run the boiler at 120 degrees. He said it would save money," This was while I was looking at a leaking cast iron boilerRay Wohlfarth
Boiler Lessons0 -
"There's no tellin, not knowin."0
Or this one from the tool crib attendant.
"We can't lend that out, we might need it !"0 -
An old timer coworker says that all the time. “I can’t see it from my house”. When something is good enough but not perfect and not worth tearing it all apart and starting over. It happens most on PVC condensate drains or when the sheet metal guy is just a little off on their dimensions.Steamhead said:Looks OK from my house!
... or anything in a crawl space or attic. Our install crews including myself are pretty green, so we make a fair share of minior mistakes, but we at least keep to bar high. We know what a perfect install looked like. The local competition keeps the bar fairly low.
A happy wife is a happy life.0
Tark machinist
When I was a facilities engineer, it was “Budget, Timeline, and Quality”. Pick 2.
Worse, you usually only get 1 or none, because you tried too hard ot minimize #1 and #2 so #3 suffered and you fail at all 3.0 -
Cheap, fast, or good. Pick any one.
Actually heard this once, IIRC.We do our best work concealed.
My old old boss.0 -
During my high school summers I learned to sweat copper and assemble cast iron soil pipe from an old timer who started my education with him with this bit of wisdom ..."**** runs downhill and Friday is payday".0
And don't bite your fingernails.Retired and loving it.0
Ben Franklin said “When the well is dry, we know the worth of water.” His brother Vladimir said "When the house is cold, we know the worth of a good hydronics technician."
Yours, Larry0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
