My bestest wrenches
Are those painted in "I dare you to steal this" purple?
Gordo said:
I am partial to the S-2 Ridgid compound wrench.
https://www.youtube.com/watch?v=odLe_3fVpq0&t=
Gordo said:I am partial to the S-2 Ridgid compound wrench.
When I bought my first 24" aluminum pipe wrench, the first thing my boss told me to do was paint it ridgid red so it looks like a steel wrench. Otherwise it will be gone in a heartbeat.
Also, my wife painted all of her hand tools pink so I wouldn't take them. Didn't work. When you need a tool, it doesn't matter what color it is.
Rick
2 -
@B_Sloane Nice Mulberry tree in the background!8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab1 -
Article a few weeks ago in Boston Globe on origin of Stillson Enjoy https://www.google.com/url?client=internal-element-cse&cx=006376928391721581342:dttdzxtrxse&q=https://www.bostonglobe.com/2019/12/06/magazine/forgotten-story-americas-most-famous-tool/&sa=U&ved=2ahUKEwi4y9rboovnAhVFbs0KHWDhB3IQFjAAegQIAhAC&usg=AOvVaw3Rn0if0lF344VrCDsElx1N1
Erectors spud wrench is another common name.mattmia2 said:I've seen the wrench with the drift on the end called an erection wrench because it is designed for erecting steel, the drift is for pulling the steel together while you get the other bolts in.
The origin of that second line about spuds seems dubious. A million commercial and industrial things still have spuds...0
I did see on the "Steve Lav" Utube a pretty good idea.
He has a small, maybe 10" pipe wrench that has thin jaws.
The handle is cut off, so if you needed a pipe wrench to work on an expansion tank, you fit the cut off wrench onto the flats of the tank nipple. Then take a 14-18" and open the jaws large enough to fit over the mini-wrench. I have watched him do this several times and works out well.1 -
Hey wrench fans, here's a new TOH video about Stillson's invention:
https://youtu.be/3RaUSUOvSlI
The one I can find when I'm looking for a wrench...Br. Jamie, osb
Anymore it seems to take two men and a boy just to look at my Ridge Tool 60 inch.
1926 1000EDR Mouat 2 pipe vapor system,1957 Bryant Boiler 463,000 BTU input, Natural vacuum operation with single solenoid vent, Custom PLC control0 -
I was in a supply store about 30 years ago and they had a 96" Ridgid pipe wrench. I thought it was a plastic display model until I tried to pick it up. So I had to ask the supply house "who was the customer" for such a huge wrench. I was told that it was going to a railroad yard to tighten nuts on parts of the old steam engines and drive train. I should have known it was for a steam customer.
I had the pleasure of using a 72" wrench to tighten a steam flange. I was much younger then.
I had a wrench with a drift on the end for aligning the bolts for flanges.1 -
I frequently ask that I be talked out of using a pipe wrench that is bigger than three feet. Im beginning to listen👀👂0
@rick in Alaska
very true. aluminum wrenches disappear. steel ones don't.
Same thing with box and open end wrenches. Chrome wrenches walk. Black steel wrenches stay0 -
i have some harbor freight aluminum pipe wrenches and i notice that they veer to the side a bit when i use then up close to something. Is this just crappy machining somewhere? I just don't use pipe wrenches enough to have aluminum rigid wrenches.0
Years ago I happened upon a collection of 6 pipe wrenches for $25 on ebay - shipping included. I bought them and a week later I heard a loud thump on my front porch.
The package had 8" to18" wrenches, all American made and all in good shape. The one i was looking for was a Ridgid offset wrench that didn't show much use at all. I gave three of them away and added the rest to my collection.
Some guy was spinning in his grave over this one. Years before this find a buddies wife sold her fathers toolbox at a yardsale for $10, her dad was a diesel mechanic and that box was full of tools. That thing weighed a ton but I'm sure the buyer ran out of there like it weighed 2 pounds.Smith G8-3 with EZ Gas @ 90,000 BTU, Single pipe steam
3PSI gauge0 -
When I was doing fire sprinkler work, we would take an 18" wrench and slide about a one foot piece of copper pipe over the handle and hammer it on to fit tight. That way, we had effectively an 18" wrench, but with a lighter wrench, and jaws that would fit in to tight areas. I still use that wrench almost daily, but the copper finally broke off and I haven't replaced it yet. 34 years of use will do that.JUGHNE said:I did see on the "Steve Lav" Utube a pretty good idea.
"Same thing with box and open end wrenches. Chrome wrenches walk. Black steel wrenches stay ."
Personally I don't like chrome wrenches as well as black ones. If you are a mechanic and are doing anything with oil, then it is very hard to hang on to the wrench.
Rick1 -
Added a 15" Ford wrench to my collection. Jaw capacity is 3¾".
Always read and was told about the Famous Parmalee Wrench, the best wrench for working on Chrome plated Brass. It grips like the human hand and leaves no
Marks on the Chrome plating. Priced one out about 10 yrs ago. Almost 1000 bucks for 1/2" pipe size. I had to fit out a very large commercial kitchen with 14 appliances all CP heavy brass. Stick w my old school tricks. Rainbow rubber, sheet lead and rosin...Mad Dog
I have several Parmalee wrenches that I have picked up at estate sales. Very few know what they are. They are also used to grip rollers in textile and paper mills.
https://parmeleewrench.com/
Seems like one little piece of debris and it's all scratched. Could do something with multi strand chain and a piece of rubber that works on more than one pipe size.0
You can't exert quite as much torque with rubber strap wrenches, but it's enough to assemble steam piping with PTFE compound or tape. (Disassembly is another story, but you don't always need to save what you're taking apart.) There are good ones and bad ones, like anything else, but the ones pictured below, with the metal levers and the reinforced straps work very well as long as there's no grease on the strap or the work, and I have a pair I've been using for about 15 years now.
Chain wrenches usually have a serrated jaw that leaves bite marks, and padding it with rubber or leather reduces the torque you can apply to about what you get with the above strap wrenches.Just another DIYer | King of Prussia, PA
1983(?) Peerless G-561-W-S | 3" drop header, CG400-1090, VXT-242 -
Mad Dog_2 said:Always read and was told about the Famous Parmalee Wrench, the best wrench for working on Chrome plated Brass. It grips like the human hand and leaves no
$100 with shipping gets you the 1/2" plus 3/8" and 3/4"Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
@JUGHNE
My Benfield was at the oil co I started working for in 73' and I ended up with it. It looked 50 years old then so I don't know how old it really is. I have had several 3/4 benders over the years that got misplaced or stolen or someone borrowed it and I never got got them back.
But the old 1/2" I always managed to hang on to. I also have a 1" T & B (Thomas & Betts) and an 1 1/4" which I think is a Greenlee....that one has an aluminum head which are just as old. Used the 1 1/4" a few times but not often. Takes a lot to crank that one lol0
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 391 Solar
- 55 Water Quality
