My bestest wrenches
2»
    ethicalpaul Member Posts: 8,922
    Are those painted in "I dare you to steal this" purple?
    Solid_Fuel_Man
  • B_Sloane
    B_Sloane Member Posts: 56
    Flame Safeguard color :)
  • BradHotNCold
    BradHotNCold Member Posts: 82
    Gordo said:
    I am partial to the S-2 Ridgid compound wrench.
    https://www.youtube.com/watch?v=odLe_3fVpq0&t=
  • BradHotNCold
    As Gordo’s video shows, the best one is the lever...
    “ Archimedes — 'Give me a lever long enough and a fulcrum on which to place it, and I shall move the world.”
    Gordo
  • BobC
    BobC Member Posts: 5,568
    I bet that purple paint discourages those wrenches from walking off.
    I have a 50ft bright pink 14-3 extension cord that I still have for the same reason.
    Bob
    3PSI gauge
    B_Sloane
  • rick in Alaska
    rick in Alaska Member Posts: 1,526
    When I bought my first 24" aluminum pipe wrench, the first thing my boss told me to do was paint it ridgid red so it looks like a steel wrench. Otherwise it will be gone in a heartbeat.
    Also, my wife painted all of her hand tools pink so I wouldn't take them. Didn't work. When you need a tool, it doesn't matter what color it is.
    Rick
    icy78SeanBeans
  • @B_Sloane Nice Mulberry tree in the background!
    B_Sloane
    mattmia2 Member Posts: 17,206
    I've seen the wrench with the drift on the end called an erection wrench because it is designed for erecting steel, the drift is for pulling the steel together while you get the other bolts in.
    Ceacel
  • B_Sloane
    Bob
    Pawn Shops around here will not take painted Tools :)
    Intplm.ethicalpaul
    hot_rod Member Posts: 27,705
    Erectors spud wrench is another common name.
    The origin of that second line about spuds seems dubious. A million commercial and industrial things still have spuds...
  • Hap_Hazzard
    Hap_Hazzard Member Posts: 2,919
    If you don't know what to call something, call it a spud. :D
    Intplm.
  • JUGHNE
    JUGHNE Member Posts: 11,591
    I did see on the "Steve Lav" Utube a pretty good idea.
    He has a small, maybe 10" pipe wrench that has thin jaws.
    The handle is cut off, so if you needed a pipe wrench to work on an expansion tank, you fit the cut off wrench onto the flats of the tank nipple. Then take a 14-18" and open the jaws large enough to fit over the mini-wrench. I have watched him do this several times and works out well.
    B_Sloane
    Hey wrench fans, here's a new TOH video about Stillson's invention: https://youtu.be/3RaUSUOvSlI
    Hap_HazzardCorktown
    The one I can find when I'm looking for a wrench...
  • PMJ
    PMJ Member Posts: 1,322
    Anymore it seems to take two men and a boy just to look at my Ridge Tool 60 inch.
    1926 1000EDR Mouat 2 pipe vapor system,1957 Bryant Boiler 463,000 BTU input, Natural vacuum operation with single solenoid vent, Custom PLC control
  • retiredguy
    retiredguy Member Posts: 1,097
    edited October 2020
    I was in a supply store about 30 years ago and they had a 96" Ridgid pipe wrench. I thought it was a plastic display model until I tried to pick it up. So I had to ask the supply house "who was the customer" for such a huge wrench. I was told that it was going to a railroad yard to tighten nuts on parts of the old steam engines and drive train. I should have known it was for a steam customer.
    I had the pleasure of using a 72" wrench to tighten a steam flange. I was much younger then.
    I had a wrench with a drift on the end for aligning the bolts for flanges.
    CLamb
  • Intplm.
    Intplm. Member Posts: 3,069
    I frequently ask that I be talked out of using a pipe wrench that is bigger than three feet. Im beginning to listen👀👂
    EBEBRATT-Ed Member Posts: 20,394
    @rick in Alaska
    very true. aluminum wrenches disappear. steel ones don't.
    Same thing with box and open end wrenches. Chrome wrenches walk. Black steel wrenches stay
    i have some harbor freight aluminum pipe wrenches and i notice that they veer to the side a bit when i use then up close to something. Is this just crappy machining somewhere? I just don't use pipe wrenches enough to have aluminum rigid wrenches.
  • BobC
    Years ago I happened upon a collection of 6 pipe wrenches for $25 on ebay - shipping included. I bought them and a week later I heard a loud thump on my front porch.
    The package had 8" to18" wrenches, all American made and all in good shape. The one i was looking for was a Ridgid offset wrench that didn't show much use at all. I gave three of them away and added the rest to my collection.
    Some guy was spinning in his grave over this one. Years before this find a buddies wife sold her fathers toolbox at a yardsale for $10, her dad was a diesel mechanic and that box was full of tools. That thing weighed a ton but I'm sure the buyer ran out of there like it weighed 2 pounds.
    3PSI gauge
  • rick in Alaska
    When I was doing fire sprinkler work, we would take an 18" wrench and slide about a one foot piece of copper pipe over the handle and hammer it on to fit tight. That way, we had effectively an 18" wrench, but with a lighter wrench, and jaws that would fit in to tight areas. I still use that wrench almost daily, but the copper finally broke off and I haven't replaced it yet. 34 years of use will do that.
    "Same thing with box and open end wrenches. Chrome wrenches walk. Black steel wrenches stay ."
    Personally I don't like chrome wrenches as well as black ones. If you are a mechanic and are doing anything with oil, then it is very hard to hang on to the wrench.
    Rick
    hot_rod
    Or get the socket off the extension or adapter.
    CLamb
  • Hap_Hazzard
    Added a 15" Ford wrench to my collection. Jaw capacity is 3¾".
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,644
    Always read and was told about the Famous Parmalee Wrench, the best wrench for working on Chrome plated Brass. It grips like the human hand and leaves no
    Marks on the Chrome plating. Priced one out about 10 yrs ago.   Almost 1000 bucks for 1/2" pipe size.  I had to fit out a very large commercial kitchen with 14 appliances all CP heavy brass. Stick w my old school tricks.  Rainbow rubber, sheet lead and rosin...Mad Dog
    Corktown
  • WMno57
    WMno57 Member Posts: 1,408
    I have several Parmalee wrenches that I have picked up at estate sales. Very few know what they are. They are also used to grip rollers in textile and paper mills.
    https://parmeleewrench.com/
    guzzinerd
    Seems like one little piece of debris and it's all scratched. Could do something with multi strand chain and a piece of rubber that works on more than one pipe size.
  • Hap_Hazzard
    You can't exert quite as much torque with rubber strap wrenches, but it's enough to assemble steam piping with PTFE compound or tape. (Disassembly is another story, but you don't always need to save what you're taking apart.) There are good ones and bad ones, like anything else, but the ones pictured below, with the metal levers and the reinforced straps work very well as long as there's no grease on the strap or the work, and I have a pair I've been using for about 15 years now.
    strap wrenches
    Chain wrenches usually have a serrated jaw that leaves bite marks, and padding it with rubber or leather reduces the torque you can apply to about what you get with the above strap wrenches.
    Alan (California Radiant) ForbesCorktown
  • guzzinerd
    guzzinerd Member Posts: 461
    https://www.ebay.com/itm/275688792613?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=J195ldk9SyW&sssrc=2349624&ssuid=FWKVlNuoS2u&var=&widget_ver=artemis&media=COPY
    $100 with shipping gets you the 1/2" plus 3/8" and 3/4"
    Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,144
    Hi, One good thing the Parmlee wrench does is to not make pipe go out of round when you need to use force, so it's good for any stubborn threaded pipe.
    Yours, Larry
    WMno57
  • JUGHNE
    Ed, my Greenlee 1/2" CI head is 54 years.....so there!
    Wife probably won't allow it in the box though.
    ratio
    @JUGHNE
    My Benfield was at the oil co I started working for in 73' and I ended up with it. It looked 50 years old then so I don't know how old it really is. I have had several 3/4 benders over the years that got misplaced or stolen or someone borrowed it and I never got got them back.
    But the old 1/2" I always managed to hang on to. I also have a 1" T & B (Thomas & Betts) and an 1 1/4" which I think is a Greenlee....that one has an aluminum head which are just as old. Used the 1 1/4" a few times but not often. Takes a lot to crank that one lol
