Buderus gb142 repair or replace
it1991
Member Posts: 7
Hi,
My boiler started leaking today (from the pipe marked with a red arrow in the picture) I had a tech come out and he recommended replacing the boiler, instead of replacing the pipe.
I just wanted to see what the professionals on here think.
And if I will be replacing, any idea of what the cost may look like? I imagine it isn’t too difficult since I have all the necessary pipes and plumbing in place.
Thank you!
Thank you!
Pictures attached0
I need to start this post with: I dont like the boiler you currently own due to lots of reasons, but mostly because everything on it is pricey to fix.
I would say if the boiler is older than 10 years I would swap it, but there are more variables than that. But if you can afford it, do the research and get yourself a good boiler.Tom
Montpelier Vt0 -
I'll take a guess based on my recent experience (tough to see what's going on in your pic).
I had a condensate plate gasket leaking onto that pipe.
See more details here ...
https://forum.heatinghelp.com/discussion/170834/buderus-gb142-multiple-corrosion-issues0 -
How old is the boiler? How well has it been maintained?
As mentioned, there's probably a leak from the collector gasket dripping on it. That would be indicative of improper maintenance since that should be removed and cleaned yearly.
That's a very easy boiler to work on and maintain. Replace the part unless something else major is wrong.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.3
