Buderus gb142 repair or replace
it1991
it1991 Member Posts: 7
Hi,
My boiler started leaking today (from the pipe marked with a red arrow in the picture) I had a tech come out and he recommended replacing the boiler, instead of replacing the pipe.
I just wanted to see what the professionals on here think.
And if I will be replacing, any idea of what the cost may look like? I imagine it isn’t too difficult since I have all the necessary pipes and plumbing in place.
Thank you!
  • kcopp
    kcopp Member Posts: 4,630
    For starters we dont talk pricing here...too many variables for area to area...
    Overall that boiler looks in good shape
    That part should be replaceable.
    STEVEusaPAIronman
  • Tom_133
    Tom_133 Member Posts: 961
    I need to start this post with: I dont like the boiler you currently own due to lots of reasons, but mostly because everything on it is pricey to fix.
    I would say if the boiler is older than 10 years I would swap it, but there are more variables than that. But if you can afford it, do the research and get yourself a good boiler.
    Tom
    Montpelier Vt
  • woobagooba
    woobagooba Member Posts: 186
    edited December 2019
    I'll take a guess based on my recent experience (tough to see what's going on in your pic).
    I had a condensate plate gasket leaking onto that pipe.
    See more details here ...
    https://forum.heatinghelp.com/discussion/170834/buderus-gb142-multiple-corrosion-issues
  • Ironman
    Ironman Member Posts: 7,858
    How old is the boiler? How well has it been maintained?
    As mentioned, there's probably a leak from the collector gasket dripping on it. That would be indicative of improper maintenance since that should be removed and cleaned yearly.
    That's a very easy boiler to work on and maintain. Replace the part unless something else major is wrong.
    Bob Boan
    HVACNUTZmanRich_49
