Cracked Boiler
  • STEAM DOCTOR
    STEAM DOCTOR Member Posts: 1,968
    Bit more then a crack. Those sections ain't lightweights.
    Steamhead Member Posts: 16,835
    Corrosion, not a crack. Burnham?
    Consulting
  • EzzyT
    EzzyT Member Posts: 1,295
    Yes a Burnham
    E-Travis Mechanical LLC
    Etravismechanical@gmail.com
    201-887-8856
    Thought so. What are you putting in?
    Consulting
  • EzzyT
    Where going with a Peerless 6304, will be finishing the install today.
    201-887-8856
  • EzzyT
    EdTheHeaterMan Member Posts: 7,837
    VERY NICE JOB!!! Drop header and all.... But the center 4" foundation block is a different color???
    Other than that is is perfect!
    Edward F Young. Retired HVAC ContractorSpecialized in Residential Oil Burner and Hydronics
    lchmbCanucker
  • EzzyT
    @EdTheHeaterMan thanks.
    That’s what the wholesaler delivered.
    201-887-8856
    I tried to post LOL
    but the Spam blocker prevented me from posting within 60 seconds
    I'm liking the job!!!
  • lchmb
    lchmb Member Posts: 2,997
    beautiful work!!
  • AMservices
    AMservices Member Posts: 610
    Wow, you work fast and do good quality. Very nice.
  • EzzyT
    @AMservices thanks, we got another one tomorrow.
    201-887-8856
  • AMservices
    Steam boilers are dropping like flies in your area. What are you doing, 3 a week?
    I'm jealous.
  • SlamDunk
    SlamDunk Member Posts: 1,580
    How old was it?
  • Hap_Hazzard
    Hap_Hazzard Member Posts: 2,846
    Nice job! I'm probably going to get that same boiler if & when my Peerless G-561 ever dies, but I'm starting to think it might outlast me.
  • The Steam Whisperer
    The Steam Whisperer Member Posts: 1,215
    Yep, we've got g series boilers ( or the prior model) installed in the 60's that are still going. Owner started using treatment before we began maintaining it and the boiler is nice and clean when we go out to service it.
    Hap_Hazzard
  • Le John
    Le John Member Posts: 226
    Very neat and tidy. Installed by a true master of their craft.
  • Intplm.
    Intplm. Member Posts: 1,949
    Beautiful work as always. Good job.
  • EzzyT
    @AMservices this week we did 3.
    @SlamDunk the old boiler was about 15 years old.
    @Hap_Hazzard @Le John @Intplm. thanks
    201-887-8856
  • SlamDunk
    Dang, I have up to five years left on mine.
  • AMservices
    Not if you have clean water, proper piping that keeps the water in the boiler, a tight system and run low pressure, No telling how long it will last.
  • SlamDunk
    I have all that. But there are an awful lot of reports of burnhams failing. Those photos look like the boiler operated under a pile of road salt.
  • AMservices
    Ooooo... sorry, didn't know you had a Burnham.
    Just kidding, but keep your fingers crossed.
    SlamDunk
  • Hap_Hazzard
    I'm curious, since this will probably be the model I end up installing, how hard would it be to get this through a couple of doorways and down a flight of stairs?
  • EzzyT
    @Hap_Hazzard are you doing the install yourself? If so you’ll need at least 2 other people to help you out bringing the boiler down the flight of stairs. We take off all the controls off before bring down the boiler.
    201-887-8856
    Hap_Hazzard
  • Hap_Hazzard
    @EzzyT Yeah, I was planning on doing the install. I can find some help getting it down the stairs. Did you use a hand truck or carry it or...?
  • EzzyT
    We use an appliance hand truck. The ones we have are rated for 1000lbs and make sure your stairs can handle the total load bodies weight and boiler.
    201-887-8856
    AMservicesHap_Hazzard
  • STEAM DOCTOR
    edited November 2019
    > @Hap_Hazzard said:
    > (Quote)
    You need to measure your doorways. Taking off jackets, burner tray and controls will give you more room. Shipping weight of boiler is something like 575 pounds.
    Hap_Hazzard
    ethicalpaul Member Posts: 5,702
    It’s the first time I have really been thankful for my bulkhead doors
    NJ Steam Homeowner. See my sight glass boiler videos: https://bit.ly/3sZW1el
  • Intplm.
    Yes. Me too. The reason the bulkhead doors are made is for loading and unloading of the big stuff mentioned above.
    Finished basements/basements with no bulkhead doors are problems. BIG problems when; a boiler , water heater, oil tank, etc. need to be changed.
