Have you ever come across scarce phenomenon of the wild while you are doing heating services ?
Roohollah
Member Posts: 135
Dear Friends,
Hope that you all are doing well and fine , as always . Indeed, heating season commences and most related businesses are getting busy . May during such season you come across something which hardly ever happened or you have witnessed.
A couple of days ago , I was told for running heating system of an office which located Tehran suburb . We were dismantling floor standing fan coils
for their yearly services that I suddenly hunted one of scarce wild phenomenons . Under the supply and return valves of a fancoil a lizard was being hunted by a spider , and both were dead . I took couple of photos of them for sharing .
I would like to know whether you capture or run into such Wild phenomenons during your work ?
I look forward to hear ,
Sincerely,
Roohollah
Sincerely,
Roohollah
2
Either one of those scenarios and when I got home there would be a 'For Sale' sign on my home and my wife would be staying with her sister.
Usually it's bees, or cooked birds/squirrels in the flue pipe.
One customer called me an told me he seen a squirrel trying to get thru the baro damper. "What should I do?" he asked. I said "Hold the damper closed with a broomstick and turn on the furnace, or hold the damper closed with a broomstick and call animal control. It depends on how you like your squirrel. And let's get a chimney cap".There was an error rendering this rich post.
2 -
- 87.1K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
