Doh!!!
>:) I thought all you steam buffs would like this.
SeanBeansmattyc
    Jamie Hall Member Posts: 27,789
    Uh... why?
    Steamhead Member Posts: 18,873
    And, how many people couldn't figure out why it didn't heat?
    You can't fix stupid!
    We'll be fixing a couple of these in the coming weeks- I'll be sure to post them too.
    Semi-retired
  • Gsmith
    Gsmith Member Posts: 444
    Well, one good feature, very little steam can get through that trap
  • gerry gill
    gerry gill Member Posts: 3,084
    Lol..that goes in the ‘don’t be that guy’ file
    gwgillplumbingandheating.com
  • Danny Scully
    Danny Scully Member Posts: 1,470
    Ahh, but can you figure out what happened? I think I know the answer...it use to be a wall hung rad.
    EBEBRATT-Ed Member Posts: 20,997
    It's new technology, part steam and part hot water.
    Maybe the radiator was to big for the space and they wanted to reduce the output LOL
  • KC_Jones
    KC_Jones Member Posts: 5,947
    He was trying to add more mass in the form of water to even out the heating between cycles. lol
    2014 Weil Mclain EG-40
  • ChicagoCooperator
    ChicagoCooperator Member Posts: 363
    And no escutcheons in the tile!!!!
  • KC_Jones
    There is also a screw missing in the outlet cover.
    Alan (California Radiant) Forbes Member Posts: 4,861
    edited October 2019
    So, that trap is always open and the radiator will never heat, correct?
    That's a major job to fix.
    EdTheHeaterMan Member Posts: 12,729
    There is a nut lose behind the pipe wrench
  • JUGHNE
    JUGHNE Member Posts: 11,634
    Rad will heat partially if pressure jacked up to 8PSI so the air will compress.
    Or drill and add air vent to rad.
    2 knucklehead answers.......... >:)
    SeanBeans
  • ScottSecor
    ScottSecor Member Posts: 1,055
    In my world we see stuff similar to this weekly, much to my surprise it works most of the time. If WE installed it like that it would never work and we would be out of business in not time.
  • ChicagoCooperator
    How did I miss that one?
  • zackwatt
    zackwatt Member Posts: 81
    :D:D:D
  • Mike Cascio
    Mike Cascio Member Posts: 143
    Its a hybrid radiator, part steam and part hot water.
    In reality, I wonder if it would heat the first time until it fills up with water then becomes a decorative accessory unless the pressure is through the roof!
