Doh!!!
>:) I thought all you steam buffs would like this.
SeanBeansmattyc
    Jamie Hall Posts: 27,834
    Uh... why?
    Steamhead Posts: 18,916
    And, how many people couldn't figure out why it didn't heat?
    You can't fix stupid!
    We'll be fixing a couple of these in the coming weeks- I'll be sure to post them too.
    Semi-retired
  • Gsmith
    Gsmith Posts: 444
    Well, one good feature, very little steam can get through that trap
  • gerry gill
    gerry gill Posts: 3,084
    Lol..that goes in the ‘don’t be that guy’ file
    gwgillplumbingandheating.com
  • Danny Scully
    Danny Scully Posts: 1,470
    Ahh, but can you figure out what happened? I think I know the answer...it use to be a wall hung rad.
    EBEBRATT-Ed Posts: 21,058
    It's new technology, part steam and part hot water.
    Maybe the radiator was to big for the space and they wanted to reduce the output LOL
  • KC_Jones
    KC_Jones Posts: 5,949
    He was trying to add more mass in the form of water to even out the heating between cycles. lol
    2014 Weil Mclain EG-40
  • And no escutcheons in the tile!!!!
  • KC_Jones
    There is also a screw missing in the outlet cover.
    edited October 2019
    So, that trap is always open and the radiator will never heat, correct?
    That's a major job to fix.
  • There is a nut lose behind the pipe wrench
  • JUGHNE
    JUGHNE Posts: 11,636
    Rad will heat partially if pressure jacked up to 8PSI so the air will compress.
    Or drill and add air vent to rad.
    2 knucklehead answers.......... >:)
    SeanBeans
  • ScottSecor
    ScottSecor Posts: 1,056
    In my world we see stuff similar to this weekly, much to my surprise it works most of the time. If WE installed it like that it would never work and we would be out of business in not time.
    How did I miss that one?
    :D:D:D
  • Its a hybrid radiator, part steam and part hot water.
    In reality, I wonder if it would heat the first time until it fills up with water then becomes a decorative accessory unless the pressure is through the roof!
