Doh!!!
The Steam Whisperer
Member Posts: 1,328
2
Uh... why?Br. Jamie, osb
And, how many people couldn't figure out why it didn't heat?
You can't fix stupid!
We'll be fixing a couple of these in the coming weeks- I'll be sure to post them too.0 -
Well, one good feature, very little steam can get through that trap0
Lol..that goes in the ‘don’t be that guy’ filegwgillplumbingandheating.com
It's new technology, part steam and part hot water.
Maybe the radiator was to big for the space and they wanted to reduce the output LOL0 -
He was trying to add more mass in the form of water to even out the heating between cycles. lol0
There is also a screw missing in the outlet cover.1
So, that trap is always open and the radiator will never heat, correct?
That's a major job to fix.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
There is a nut lose behind the pipe wrench
In my world we see stuff similar to this weekly, much to my surprise it works most of the time. If WE installed it like that it would never work and we would be out of business in not time.0
How did I miss that one?KC_Jones said:There is also a screw missing in the outlet cover.
Its a hybrid radiator, part steam and part hot water.
In reality, I wonder if it would heat the first time until it fills up with water then becomes a decorative accessory unless the pressure is through the roof!0
- 87.8K THE MAIN WALL
- 130 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
