Dopey
retep
Member Posts: 13
So many conflicting opinions about pipe dope how about permatex pipe joint compound
Sure0
The reason their is conflicting opinions is because it's not really that important on the average job. Jobs with really high temperatures and pressures...different story
People use what works for them and on most jobs anything will work. People have their preferences, what their father told them, what their boss or co-worker told them or the brand of dope they used in shop class or trade school.
Chevy, Ford or Dodge they all drive down the same road4 -
Blue monster tape and megaloc dope going on 8 years now no issues. For real big pipe threads, old school lamp wicking and blue block dope. Blue block sucks to clean up though. LolDL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......1 -
I've used Megaloc on steam pipes and on a pressure washer running 2800 PSI on NPT threads.
Teflon tape followed by Teflon dope for decades. Why switch?Steve Minnich0
Isn't Permatex that black thick paint like compound? If so, I know it takes Herculean strength to wrench loose cured fittings. Worse than Leak Lock.0
Teflon and Megaloc for me. I used Teflon and Rectorseal for years and just got fed up with the dope oozing out whenever the can got knocked over
Megaloc is easier to spread when its colder out , compared to other dopes.
From time to time I'd try to use one or the other. Just Teflon or just dope. Never worked as planned .....0 -
Willpermatex pipe dope dissolve Teflon tape it is alcohol based0
I tend toward blue monster ribbon tape and megaloc pipe dope, but did my 4” header with permatex high temp gasket sealer with zero issues.gwgillplumbingandheating.com
Nope use what ever works for you..............EBEBRATT-Ed said:Like I said, with so many differing opinions on the average job does it matter?
- 87.1K THE MAIN WALL
- 58 Biomass
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
