Dopey
retep
retep Member Posts: 13
So many conflicting opinions about pipe dope how about permatex pipe joint compound
  • GroundUp
    GroundUp Member Posts: 2,465
    Sure
    EBEBRATT-Ed Member Posts: 19,558
    The reason their is conflicting opinions is because it's not really that important on the average job. Jobs with really high temperatures and pressures...different story
    People use what works for them and on most jobs anything will work. People have their preferences, what their father told them, what their boss or co-worker told them or the brand of dope they used in shop class or trade school.
    Chevy, Ford or Dodge they all drive down the same road
    CanuckerSteve MinnichLarry WeingartenIronman
  • Dave0176
    Dave0176 Member Posts: 1,178
    Blue monster tape and megaloc dope going on 8 years now no issues. For real big pipe threads, old school lamp wicking and blue block dope. Blue block sucks to clean up though. Lol
    DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
    NJ Master HVACR Lic# 4630
    I cannot force people to spend money, I can only suggest how to spend it wisely.......
    Ironman
  • ChrisJ
    ChrisJ Member Posts: 17,068
    I've used Megaloc on steam pipes and on a pressure washer running 2800 PSI on NPT threads.
  • Steve Minnich
    Steve Minnich Member Posts: 2,868
    Teflon tape followed by Teflon dope for decades. Why switch?
    Steve Minnich
    HVACNUT Member Posts: 7,228
    edited August 2019
    Isn't Permatex that black thick paint like compound? If so, I know it takes Herculean strength to wrench loose cured fittings. Worse than Leak Lock.
  • Ron Jr._3
    Ron Jr._3 Member Posts: 605
    Teflon and Megaloc for me. I used Teflon and Rectorseal for years and just got fed up with the dope oozing out whenever the can got knocked over :)
    Megaloc is easier to spread when its colder out , compared to other dopes.
    From time to time I'd try to use one or the other. Just Teflon or just dope. Never worked as planned .....
  • retep
    Willpermatex pipe dope dissolve Teflon tape it is alcohol based
  • ChrisJ
    edited August 2019
    As far as I know alcohol doesn't do anything to PTFE.
  • gerry gill
    gerry gill Member Posts: 3,083
    I tend toward blue monster ribbon tape and megaloc pipe dope, but did my 4” header with permatex high temp gasket sealer with zero issues.
    gwgillplumbingandheating.com
    Like I said, with so many differing opinions on the average job does it matter?
    Canucker
  • Dave0176
    Nope use what ever works for you..............
    Canucker
