Boiler Room Picture I can use
RayWohlfarth
Greetings
I will be teaching a class on the benefits of hydronic versus air and was hoping to get a picture of a nice hydronic boiler room, perhaps with the metal diamond plate on the wall. If there is a picture of a boiler room where you are proud, please post it so I can use it
Thanks in advance
Thanks in advance
Ray Wohlfarth
Boiler Lessons
Boiler Lessons
Ray, if you wanna search my posts, you're welcome to use anything (good or bad) that you find.Bob Boan
Here are a coupleServing Northern Maine HVAC & Controls. I burn wood, it smells good!1
Here is one I did at a radiant shop.
And a shoe horn under the stairs small radiant oil Toyotomi.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0 -
I hope you're including steam as well. If so, feel free to use any of ours- here are a few, first three are of the same big job:
https://forum.heatinghelp.com/discussion/170284/all-steamed-up-inc-installs-a-weil-mclain-480-steam-boiler-with-a-carlin-commercial-gas-burner
https://forum.heatinghelp.com/discussion/170152/weil-mclains-sgo-steam-boiler-installed-and-fired-with-a-carlin-ez-gas-burner
https://forum.heatinghelp.com/discussion/167918/splitting-a-church-steam-system
https://forum.heatinghelp.com/discussion/153445/boiler-replacement-on-larger-webster-type-r-system-finally-ready-to-post
https://forum.heatinghelp.com/discussion/148298/atmospheric-out-power-burner-in
and last but not least, a MegaSteam:
https://forum.heatinghelp.com/discussion/144144/latest-megasteam1 -
I’m not a fan of diamond plate. I used it twice 15-20 years ago, never used it again. I think it detracts from the work. But, that’s just me.Steve Minnich0
I tried tread plate a few times also. I found it harder to mount on and get holed drilled exactly where you want them. Not so easy to wipe clean or re-polish either.Steve Minnich said:I’m not a fan of diamond plate. I used it twice 15-20 years ago, never used it again. I think it detracts from the work. But, that’s just me.
Customers love the look of it when it is shiny and new
I appreciate the workmanship and clever use of a space and product more that the backing material. Plenty of pics on FB and Instagram.
Wow You guys are the best Thank you all. I am teaching a class for the steamfitters and want to discuss how boilers are still relevent. Thank you @Ironman , @Solid_Fuel_Man , @Steamhead , @gennady for the pics
@Ironman I like the wood LOL
@hot_rod I never thought of that I bet it would be tough to drill in the exact spotRay Wohlfarth
Boiler Lessons1 -
I prefer the look of the European tread plate, smaller bars, tighter spacing, more of a herringbone look. I don't see it around the US often.RayWohlfarth said:Wow You guys are the best Thank you all. I am teaching a class for the steamfitters and want to discuss how boilers are still relevent. Thank you @Ironman , @Solid_Fuel_Man , @Steamhead , @gennady for the pics
I’m a Paint It Black type guy.Steve Minnich0
One from 2 years ago.Steve Minnich2
Enameled .040 aluminum sheets. 4X10 in any color are around 60 bucks here. Build it all on the plywood first, slip the aluminum under it what it is cleaned and pressure tested.
Aluminum angle around the edges for a picture frame look.Bob "hot rod" Rohr
Ray Wohlfarth
Boiler Lessons0 -
I remember @Mark Eatherton posted a pic of a huge radiant job with diamond plates on the wall, maybe 5 years ago
Here's some steam:
Bob Boan
Ray Wohlfarth
Boiler Lessons0 -
It was house overlooking I70 just West of Denver. The first Charlie Angels movie was filmed there. Mark truly outdid himself on that one.STEVEusaPA said:I remember @Mark Eatherton posted a pic of a huge radiant job with diamond plates on the wall, maybe 5 years ago
Albert Einstein1 -
One from a year ago. My last installation ever. Took out two cast iron boilers in a large apartment building, radiant throughout.Steve Minnich1
Will this work? One of my favorite boiler rooms lolNever stop learning.0
@Mike_Sheppard certainly the coolest looking burners ever!Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
@Solid_Fuel_Man 63,000,000 btu/hr each. There’s a third one as well opposite of those two.Never stop learning.1
Thats a great looking job @Steve Minnich .Steve Minnich said:One from 2 years ago.
Am I mistaken or is that a "T" drill type of manifold you installed?0 -
@Intplm. Good eye. The tees were pulled, but not by me. I bought the manifold from Alberta, I think?Steve Minnich1
Years ago, I suggested the creation of a Heating Help calendar, with pictures of a mix of old and new boiler rooms, with the occasional grizzled steam fitter.
Maybe it’s time for that now, with enough white space for the company name, and for marking down any service notes,-
April 1, fixed dripping PRV with a pipe plug!—NBC1 -
Ray Wohlfarth
Boiler Lessons0
- 133 Chimneys & Flues
