sealer for a drain pan
Does anyone know of a product that can seal a plastic evaporator drain pan that they have had good results with. Looking or suggestions. Thanks to all.
    EBEBRATT-Ed Member Posts: 20,091
    Since it's plastic it must be cracked and not rotted. So epoxy would be more permanent. If it's in a spot you can use it. Silicone would be a more temporary repair
    zepfan
  • Ironman
    Ironman Member Posts: 7,902
    Try this:
    Bob Boan
    Intplm.
  • mikeg2015
    mikeg2015 Member Posts: 1,194
    I used some epoxy and cut a patch wit ha small piece of metal. this was to seal one of the drains that broke off.
    Most epoxy stick to about any surface and material. Best results might be to put down some epoxy, then a small piece of fiberglass cloth placed over the crack then epoxy over it. might need a slower setting epoxy for this.
    zepfan
    HVACNUT Member Posts: 7,414
    Ask the Flex Seal guy.
  • Leon82
    Leon82 Member Posts: 684
    On one of my local Facebook groups people use it to seal their pool liner.
