sealer for a drain pan
zepfan
Member Posts: 467
Does anyone know of a product that can seal a plastic evaporator drain pan that they have had good results with. Looking or suggestions. Thanks to all.
Try this:Bob Boan
You can choose to do what you want, but you cannot choose the consequences.1 -
I used some epoxy and cut a patch wit ha small piece of metal. this was to seal one of the drains that broke off.
Most epoxy stick to about any surface and material. Best results might be to put down some epoxy, then a small piece of fiberglass cloth placed over the crack then epoxy over it. might need a slower setting epoxy for this.1 -
Ask the Flex Seal guy.0
