Press fitting
Zman
Member Posts: 7,611
I found this one the other day. It is on a 10 year old significantly over pumped domestic recirc pipe. The pipe ends were reamed and installation looked correct. Not sure what brand fitting.
Albert Einstein
Albert Einstein
Was that a leaker too?0
Was 1 o ring missing??0
It was leaking. The O ring fell out after the cut."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Velocity must of got that -O- ring. Had to have!?0
The O ring was intact the leak was at the corroded ares concealed by the pipe."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Please explain, or describe, over pumped.0
Send it to Viega and let them check it!Zman said:I found this one the other day. It is on a 10 year old significantly over pumped domestic recirc pipe. The pipe ends were reamed and installation looked correct. Not sure what brand fitting.
https://www.viega.us/en/homepage.html
10 years is fairly young for a failure but like anything else the install is important. I've seen solder joints fail quicker then that...…………….
Some were mine!0 -
It is best practice to not exceed 4 ft/sec through copper piping.Gilgo said:Please explain, or describe, over pumped.
When it comes to 24/7/365 domestic recirc, particularly with aggressive water, 2 ft/sec or less is a better plan. This building originally had a 3/4 hp close coupled circ. I don't know the exact flow rates but they certainly were greater than 10 ft/sec.
http://s3.supplyhouse.com/product_category_files/11448-Flow-Rate-Chart.pdf"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Was it even a viega fitting? Lots of cheap knock offs out there0
Some of the fittings in the building are viega. That fitting did not have a brand stamp."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0
- 15.8K Strictly Steam
