Press fitting
Zman
Zman Member Posts: 7,614
I found this one the other day. It is on a 10 year old significantly over pumped domestic recirc pipe. The pipe ends were reamed and installation looked correct. Not sure what brand fitting.
Albert Einstein
  • Intplm.
    Intplm. Member Posts: 3,124
    Was that a leaker too?
    EBEBRATT-Ed Member Posts: 20,782
    Was 1 o ring missing??
  • Zman
    It was leaking. The O ring fell out after the cut.
    Albert Einstein
  • Intplm.
    Velocity must of got that -O- ring. Had to have!?
  • Zman
    The O ring was intact the leak was at the corroded ares concealed by the pipe.
    Albert Einstein
  • Gilgo
    Gilgo Member Posts: 5
    Please explain, or describe, over pumped.
    pecmsg Member Posts: 7,403
    Send it to Viega and let them check it!
    https://www.viega.us/en/homepage.html
    10 years is fairly young for a failure but like anything else the install is important. I've seen solder joints fail quicker then that...…………….
    Some were mine!
  • Zman
    It is best practice to not exceed 4 ft/sec through copper piping.
    When it comes to 24/7/365 domestic recirc, particularly with aggressive water, 2 ft/sec or less is a better plan. This building originally had a 3/4 hp close coupled circ. I don't know the exact flow rates but they certainly were greater than 10 ft/sec.
    http://s3.supplyhouse.com/product_category_files/11448-Flow-Rate-Chart.pdf
    Albert Einstein
  • Harvey Ramer
    Harvey Ramer Member Posts: 2,292
    That looks like a classic case of cavitation corrosion.
    Zman
  • Kybeans403
    Kybeans403 Member Posts: 56
    Was it even a viega fitting? Lots of cheap knock offs out there
  • Zman
    Some of the fittings in the building are viega. That fitting did not have a brand stamp.
    Albert Einstein
