Lost Art of Steam Heat - Which version to buy?
Sam007
Member Posts: 2
New to Steam Heat, silly question, but hope someone can point me in the right direction?
The book “Lost Art of Steam Heat”. Assume I buy the revised version and assume it contains all the information in original version?
I am about to convert my single pipe steam system from oil to gas. Also want a couple of other things addressed, main vent, rad vents, some clinking sounds...etc. Therefore I want to learn as much as I can before I select a Steam Heat expert.
Also does anyone recommend any experts in the Madison NJ area?
Thanks in advance
Paul
Thanks in advance
Paul
Exactly. Thanks!Jamie Hall said:Revised version has everything in the original, plus more...
President
HeatingHelp.com1 -
Thanks for the quick responses. I will buy the book and also take a look at Greening Steam too.
If anyone had any good recommendations for Steam Experts in my area, Madison NJ, I would appreciate.0 -
Did you try @EzzyT or @Dave0176 as I suggested?Sam007 said:Thanks for the quick responses. I will buy the book and also take a look at Greening Steam too.
If anyone had any good recommendations for Steam Experts in my area, Madison NJ, I would appreciate.Br. Jamie, osb
@Sam007 you can reach me at 201-887-88561
- 50 Industry Classes
