Lost Art of Steam Heat - Which version to buy?
New to Steam Heat, silly question, but hope someone can point me in the right direction?
The book “Lost Art of Steam Heat”. Assume I buy the revised version and assume it contains all the information in original version?
I am about to convert my single pipe steam system from oil to gas. Also want a couple of other things addressed, main vent, rad vents, some clinking sounds...etc. Therefore I want to learn as much as I can before I select a Steam Heat expert.
Also does anyone recommend any experts in the Madison NJ area?
Thanks in advance
Paul
  • ratio
    ratio Posts: 4,304
    Both, of course...
    foresthillsjdSeanBeans
    Jamie Hall Posts: 27,738
    Revised version has everything in the original, plus more...
    On experts, try @EzzyT or @Dave0176 .
    Sam007
  • Revised version has everything in the original, plus more...
    Exactly. Thanks!
    President
    HeatingHelp.com
    Sam007
  • Grab Greening Steam while you’re at it. They go very well together. It has a been a great resource to show my customers.
    Never stop learning.
    Sam007foresthillsjd
  • Sam007
    Sam007 Posts: 2
    Thanks for the quick responses. I will buy the book and also take a look at Greening Steam too.
    If anyone had any good recommendations for Steam Experts in my area, Madison NJ, I would appreciate.
    Did you try @EzzyT or @Dave0176 as I suggested?
    Sam007
  • EzzyT
    EzzyT Posts: 1,380
    @Sam007 you can reach me at 201-887-8856
    E-Travis Mechanical LLC
    Etravismechanical@gmail.com
    201-887-8856
    Sam007
  • STEVEusaPA
    STEVEusaPA Posts: 6,505
    You should buy both :)
    Sam007
  • Ditto, You have steam is also a good reference.
    Sam007foresthillsjd
