Comfort Aire Mini Split
Have A COMFORT AIRE MINI SPLIT air conditioner.
Operation indicator light flashes rapidly. Unit won’t respond to remote. Reset breaker and unit will respond to remote and run for 1 minute, then shuts off and operation indicator light flashes again. Unit is 5 yrs old.
I'd like to try and fix this myself before I call In the troops. Can somebody help me troubleshoot this?
  • ratio
    ratio Member Posts: 4,174
    Check the manual or Google for flash codes.
    EBEBRATT-Ed Member Posts: 19,420
    Check air filter, check to see if fans and compressors run when it starts. Anything more than that you need a service tech
    Ironman
  • mikeg2015
    mikeg2015 Member Posts: 1,194
    Need more info. IS it still heating at all? IS the outdoor unit running? IS outdoor unit defrosting? Fan running, covered in ice? Need ot check full codes.
