Why not convert to natural gas??
If CO was high that would be a real danger. PROVIDING the tech took the readings before the draft damper. Too many variables0
Cleaning the boiler: it’s all easy when you know what you’re doing😀1
OK so my android doesn't like to play with microsoft & the video is too big of file. Anyway the 1/2 foot meter turns one total revolution every 12 seconds..........................Charlie from wmass said:Double the fire rate is an immediate danger. Wow! Please confirm the rotation of the meter
And it’s easier to move the video to YouTube and then paste the link, but I think you’re good, just need a good sweeping1
1.05 is 147000 unless I’m having a bad math moment1
I don’t really like to rely on the 1/2 foot dial, maybe I’m too OCD who knows. But did you make a mistake on the 4 cu fit per minute? Your two numbers don’t align with each other. Maybe time for a tie breaker1
Well, THAT's a relief.
A good cleaning, proper burner tuning and combustion test, and you'll be in a lot better shape.
Still need to know if the boiler has the proper gas-type barometric with a blocked-flue switch on it. This is the swinging disc that is mounted in the smoke pipe. Post a pic of this so we can see.
Then you can work on getting your steam system optimized.All Steamed Up, Inc.
Consulting0 -
No blocked flue switch........don't scold me as I just learned this yesterday. The man that Tim M suggested is who I am going to get to tweak my system & make sure that the orifice, diffuser plate is correct ETC. I'm sure that he will mention that the flue is an issue............Steamhead said:Well, THAT's a relief.
@Steamhead FYI the pic is from last year and I know it's not the best.0
Uhoh now you’re gonna get some feedback on the general boiler installation 😀3
Here is a thread with pics of what a well-installed steamer should look like. It contains a link to one we did:
https://forum.heatinghelp.com/discussion/168108/most-times-when-we-post-a-diy-installAll Steamed Up, Inc.
Consulting1 -
@Steamhead not to inflate your ego or anything but I have that photo as a reference for when I do my drop header and move my equalizer pipe to where it belongs! You sir are a master at your craft!1
I detest spell correction on my phone......0
You thought that was bad..............adasilva said:I detest spell correction on my phone......
Well, I tried to link to some "Damn You Auto-Correct" videos but they displayed in such a way as would tarnish the reputation of this family-friendly site- check them out on YouTube.
Consulting1 -
@gfrbrookline if the young man I contacted does not touch base with me by next week I will see if he can help me out!0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
