Brick chimney above roof is in bad shape. Should I rebuild or replace with class b vent?
jlonj
Member Posts: 23
About to replace my roof with standing seam and realizing I should probably address my chimney. I had it inspected a few years back and one chimney guy said it needed repointing. The other said it needed to be rebuilt. I’m no expert, but the bricks look pretty bad ( I have the same bricks in the foundation and attic... they don’t look that bad).
Since the inspections, I switched to a gas boiler and the contractor installed an aluminum liner. I also power vented my water heater. So, the only thing venting through the chimney is the boiler. I have a gas fireplace that I’ve never used that I think is technically disconnected.
Would it make more sense to rebuild the chimney as-is with new bricks or to tear it down to the roof line
(Or maybe the attic) and put a b vent on it?
A couple other considerations: I may want to finish the attic eventually and that chimney takes up a ton of space. I also may want to install a fireplace insert, though it’s at the bottom of my priority list.
Picture?"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
A proper inspection with a camera on the inside of the chimney will tell you if it's sound.
Obviously the top needs more than re-pointing.There was an error rendering this rich post.
The question isn't "does it need re-pointing", the question is, when is it going to collapse? Someone, sometime, did a really poor job of re-pointing... If it were mine to do, I'd take it down to the roof and probably a course or two inside the roof -- there will have been some water damage - and rebuild it and have it properly lined.Br. Jamie, osb
Just to close out this thread if anyone ever comes back to read it.
Quote for rebuild came in at only $... much less than I was worried about. I have a strong assumption that a mason will charge less than a chimney sweeper, so do some searching - masons are hard to find.0 -
I find that getting a chimney repointed or even rebuilt from the roof up is cheaper when done through a roofer. In my case they sent a 70 year old guy and a young helper down and they rebuilt the chimney from the roof up in about 3 hours and the bill was very reasonable, the shingles and dumpster were dropped off that afternoon and the roof was done the next day.
3PSI gauge0 -
@BobC I thought about that. Reached out to my roofer but haven't heard back. I was concerned that I would get to a spot where I needed the chimney fixed ASAP to continue the roof ,and be goaded into paying a higher price. Also, I just got the sense that roofers tend to repoint over rebuilding. My quote for repointing in the past was about as much as this rebuild...0
Tuckpointing just a chimney isn’t that expensive. Not really that hard of a DIY job, but need a few special tools and getting the mortar mix right.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
