Large oversize replacement
Dave0176
Member Posts: 1,178
Old boiler was a Burnham IN9 installed in 2009, that rotted above the water line. EDR was 420. So we went with a Peerless 63-04L. Almost done....
DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......
3
Nice.
Who's the guy hiding behind the boiler?
Bob Boan
That's my Dad, 66 years old and still going.Ironman said:Nice.
I cannot force people to spend money, I can only suggest how to spend it wisely.......1 -
Thanks as always @EzzyT and it was a bit of a learning curve since I installed exclusively Weil-McLain boilers for over 10 years, however through the whole process I weighed pros and cons and I must say I like the Peerless. I like the use of K-wool sealing instead of retort cement, less screws, and most of all that block is heavy cast iron.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
I cannot force people to spend money, I can only suggest how to spend it wisely.......0 -
Couple pics
Beauty. Nice move swapping out the cyclegard0
Shhhhh
We’re not allowed to do that.........Lol
Yes, the Kaowool is alot better. With furnace cement you can figure maybe one season before it will start leaking. Probably cheaper to supply, lower quality and more time for installation. Really heavy blocks.To learn more about this professional, click here to visit their ad in Find A Contractor.0
One word: Skeet.STEAM DOCTOR said:Should have saved all of the cyclegards that I removed and made a public bonfire
Very nice install. Sweet!
We're going to have to get used to those Peerless boilers ourselves real soon....New England SteamWorks
newenglandsteamworks.com-1 -
I wish the tappings for the water seal was in a different spot, they make it awkward especially if you need to use a secondary pressuretrol: manual reser0
- 50 Industry Classes
