Sight glass on main shows a surprise
But water started pouring through the main. I had put in some Rectorseal 8-way after I did two skimmings and I guess it released a bunch of mud.
So I’m going to drain it and refill with just water to see if it does better.
It reminded me of Willy Wonka (the original of course). Enjoy!
Free NJ and remote steam advice:
https://heatinghelp.com/find-a-contractor/detail/new-jersey-steam-help/
See my sight glass boiler videos:
https://bit.ly/3sZW1el
Where did you get that? That looks awesome.0
> @Danny Scully said:
> Come on now, if you can spend money on that, and install it...you can repipe the boiler!
Not until Spring, and maybe not until new boiler purchase! 😃NJ Steam Homeowner.
It’s a connector system called Tri-Clamp. This stuff is used in breweries, etc and I thought it would be cool. It’s rated for really high temps and pressure. Here’s what you see there:
1.5” sight glass:
https://www.amazon.com/dp/B07D29WV92?ref=yo_pop_ma_swf
1” NPT adapter: https://www.amazon.com/dp/B074W76F1N/ref=cm_sw_r_cp_api_i_fd8cCbG6T2NHA
Tri-clamp 2-pack (includes gaskets)
https://www.amazon.com/dp/B073J7D1WN?ref=yo_pop_ma_swfNJ Steam Homeowner.
Here’s part 2 after a skim to clear water, and two drain and fills. Is my NBP just a really good water pump???
Edit for future viewers: When I look at this video today I'm pretty sure that it was no longer carrying boiler water into the main (in this video). It was just condensate. But yes, the piping was all wrong. See my later discussions on HH where I did re-pipe my weird header to make it a lot better)
https://youtu.be/5FPvOcOWU8A
See my sight glass boiler videos: https://bit.ly/3sZW1el3 -
I thought about it and now I’m sure it’s the piping. The boiling water and steam go up to my “header” and since the header doesn’t go straight to the equalizer to allow the water to fall down, it’s acting like an old fashioned percolator carrying/pushing the water all the way up the riser to the main!
I’ve seen boilers piped with undersized pipes and improper equalizers just pick up all of the water in the boiler and throw it into the mains..
The company who installed it blamed it on the fact that they only had steam baseboards, which were pitched the wrong way with too small of pipes. Try figuring that one out1 -
This really is a fantastic illustration of how those "vertical headers" don't work.
Really good stuff.1 -
@ethicalpaul You can get those larger and with threaded adapters, if you wanted to put them on, say, your header. Available up to 4 inch
The tri-clamp connectors will allow the piping to move without loosening, if you tighten them properly
You can have it good, fast or cheap. Pick two2 -
- 58 Biomass
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 967 Plumbing
- 385 Solar
- 15.3K Strictly Steam
