100% Eff. WH
Dan Foley
Member Posts: 1,258
Looked at this one earlier today. At first glance, I thought it was an electric tankless. Then I saw the gas line. DIY install. He’s lucky he did not burn his house down or kill his family.
What are the discharge vent temps on such a unit?Dan Foley said:Looked at this one earlier today. At first glance, I thought it was an electric tankless. Then I saw the gas line. DIY install. He’s lucky he did burn his house down or kill his family.
Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
I hope you removed the gas flex line or otherwise disabled it...........All Steamed Up, Inc.
Consulting0 -
@ Steamhead. Turned off breaker. Shut off gas supply. The house is vacant.0
Bob Boan
Consulting0 -
and they advertise
Ideal for small apartments, flats, hunting cabins and small homes as well as boats, campers, RV and Mobile Homes
Vent-Free Technology: No expensive Flue required. Other similar size heaters require a costly flue installation.-1 -
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
