100% Eff. WH
Dan Foley
Dan Foley Member Posts: 1,268
edited October 2018 in THE MAIN WALL
Looked at this one earlier today. At first glance, I thought it was an electric tankless. Then I saw the gas line. DIY install. He’s lucky he did not burn his house down or kill his family.
  • ChrisJ
    ChrisJ Member Posts: 17,069
    Dan Foley said:
    Looked at this one earlier today. At first glance, I thought it was an electric tankless. Then I saw the gas line. DIY install. He’s lucky he did burn his house down or kill his family.
    What are the discharge vent temps on such a unit?
  • Dan Foley
    edited October 2018
    @ChrisJ. I don’t know the answer but it was hot enough to scorch the Sheetrock ceiling. Hence the sheet metal flame shield.
    Steamhead Member Posts: 18,205
    I hope you removed the gas flex line or otherwise disabled it...........
    Consulting
  • Dan Foley
    @ Steamhead. Turned off breaker. Shut off gas supply. The house is vacant.
  • Ironman
    Ironman Member Posts: 7,858
    Hmm, Darwin Award??? :o
    Yours, Larry
    Exactly! That was my first thought.
    Bob Boan
    Wonder why?
    Consulting
  • ratio
    ratio Member Posts: 4,176
    Haunted. The place makes everyone feel like something isn't quite right around them. As soon as they leave, they feel better.
    Solid_Fuel_ManGroundUp
    pecmsg Member Posts: 6,780
    and they advertise
    Ideal for small apartments, flats, hunting cabins and small homes as well as boats, campers, RV and Mobile Homes
    Vent-Free Technology: No expensive Flue required. Other similar size heaters require a costly flue installation.
  • SuperJ
    SuperJ Member Posts: 609
    I'm pretty sure that is an outdoor water heater. I've seen them for RVs installed outside.
    Solid_Fuel_Man
