boiler staging control based on temp drop
mottywalter
Member Posts: 4
Does someone know of a boiler staging control based on programble temp. drop only !! not on time
I'm not familiar with the hydronic controls available, but Honeywell makes a T775 controller with a collection of output forms like relay, floating, and analog; as well as reset on certain models. Fairly flexible, yet simple to install, wire, and program.
I've used them for modulating SCR heat with reset, modulating heat & cool, staged cooling, and staged cooling with modulating heat.
I would second this suggestion.ratio said:I'm not familiar with the hydronic controls available, but Honeywell makes a T775 controller with a collection of output forms like relay, floating, and analog; as well as reset on certain models. Fairly flexible, yet simple to install, wire, and program.
The hardest part is figuring which T775 you need.
Very simple to program."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Check out HBX. The CPU-0550 allows for you to stage up to 3 boilers w/ outdoor reset. www.hbxcontrols.com0
Tekmar controls has good options0
Are you looking to essentially enable multiple single stage boilers based on OAT?Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
- 117 Geothermal
