boiler staging control based on temp drop
mottywalter
mottywalter Member Posts: 4
edited July 2018 in Thermostats and Controls
Does someone know of a boiler staging control based on programble temp. drop only !! not on time
  • ratio
    ratio Member Posts: 4,244
    I'm not familiar with the hydronic controls available, but Honeywell makes a T775 controller with a collection of output forms like relay, floating, and analog; as well as reset on certain models. Fairly flexible, yet simple to install, wire, and program.
    I've used them for modulating SCR heat with reset, modulating heat & cool, staged cooling, and staged cooling with modulating heat.
  • Zman
    Zman Member Posts: 7,612
    I would second this suggestion.
    The hardest part is figuring which T775 you need.
    Very simple to program.
    Albert Einstein
  • KVieira
    KVieira Member Posts: 5
    Check out HBX. The CPU-0550 allows for you to stage up to 3 boilers w/ outdoor reset. www.hbxcontrols.com
  • Sam81
    Sam81 Member Posts: 37
    Tekmar controls has good options
  • Solid_Fuel_Man
    Are you looking to essentially enable multiple single stage boilers based on OAT?
