Unexpected Pressuretrol Tree Appendage
New England SteamWorks
Member Posts: 1,528
I found this today:
The valved copper pipe off the tree had me scratching my head. To make matters worse, I could not follow it outside of the boiler room. The adjacent room has had two dropped ceilings installed over the decades, and it runs above the 1st (highest) dropped ceiling. So no access at all.
My inclination is to just shut the valve off. But, I thought I'd throw it up here. See if anyone has any possible explanation. It's a standard 1-pipe system in a church. Nothing special or unusual otherwise.
Thanks.
Thanks.
newenglandsteamworks.com
Looks like a sprinkler head in front of the tree.0
Any wires running up that direction? I was thinking remote mounted high limit somewhere more accessible than the boiler room. Now i'd really like to know for sure.0
No wires, and the boiler room is very accessible. There is a sprinkler head, -but not on the treeNew England SteamWorks
newenglandsteamworks.com0 -
someone needed steam for something and they hit the easy button. Not supposed to take steam off of the control header though.
It's not MU water I hope????0 -
maybe it heats the holy water so its not so cold when the priest splashes you with it.gwgillplumbingandheating.com
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.1 -
I'm still curious what it could be doing there. It would seem a bit unorthodox to use that extension to fill the boiler from on high0
Heater or humidifier for pipe organ?
But the slope on the horizontal pipe is such that water would set on the left end of the pipe.0 -
Maybe a tap to some other control?0
get up there and find out,lol
"The bitter taste of a poor install lasts far longer than the JOY of the lowest price"0 -
Maybe it's a remote pressure/vacuum gauge like the one in the 1910 Louis P. Best mansion in Davenport, Iowa.Dave in Quad Cities, America
http://grandviewdavenport.com0 -
Could be a dangerous condition, you better check, even if it means a few holes. Curiosity has nothing to do with it.
At least, that's what I'd tell them.
I closed the valve...New England SteamWorks
Good show. Now let us know who screams about what so we can find out what it did!New England SteamWorks said:I closed the valve...
Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England2
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
