Unexpected Pressuretrol Tree Appendage
I found this today:
The valved copper pipe off the tree had me scratching my head. To make matters worse, I could not follow it outside of the boiler room. The adjacent room has had two dropped ceilings installed over the decades, and it runs above the 1st (highest) dropped ceiling. So no access at all.
My inclination is to just shut the valve off. But, I thought I'd throw it up here. See if anyone has any possible explanation. It's a standard 1-pipe system in a church. Nothing special or unusual otherwise.
Thanks.
New England SteamWorks
newenglandsteamworks.com
  • Double D
    Double D Member Posts: 467
    Looks like a sprinkler head in front of the tree.
  • nicholas bonham-carter
    Maybe someone needs to steam milk for cappuccino?—NBC
    Double DCanucker
  • Dan_NJ
    Dan_NJ Member Posts: 268
    Any wires running up that direction? I was thinking remote mounted high limit somewhere more accessible than the boiler room. Now i'd really like to know for sure.
  • New England SteamWorks
    New England SteamWorks Member Posts: 1,529
    edited May 2018
    No wires, and the boiler room is very accessible. There is a sprinkler head, -but not on the tree
    EBEBRATT-Ed Member Posts: 20,194
    edited May 2018
    someone needed steam for something and they hit the easy button. Not supposed to take steam off of the control header though.
    It's not MU water I hope????
  • gerry gill
    gerry gill Member Posts: 3,084
    maybe it heats the holy water so its not so cold when the priest splashes you with it. :D
    gwgillplumbingandheating.com
  • Dan_NJ
    I'm still curious what it could be doing there. It would seem a bit unorthodox to use that extension to fill the boiler from on high ;)
  • JUGHNE
    JUGHNE Member Posts: 11,550
    Heater or humidifier for pipe organ?
    But the slope on the horizontal pipe is such that water would set on the left end of the pipe.
  • the_donut
    the_donut Member Posts: 374
    Maybe a tap to some other control?
  • ChrisJ
    ChrisJ Member Posts: 17,391
    Maybe someone installed a Magnehelic in their office? ;)
    Solid_Fuel_ManMilanD
  • newagedawn
    newagedawn Member Posts: 585
    get up there and find out,lol
    "The bitter taste of a poor install lasts far longer than the JOY of the lowest price"
  • Dave in QCA
    Dave in QCA Member Posts: 1,806
    Maybe it's a remote pressure/vacuum gauge like the one in the 1910 Louis P. Best mansion in Davenport, Iowa.
    Dave in Quad Cities, America
    http://grandviewdavenport.com
  • ratio
    ratio Member Posts: 4,238
    Could be a dangerous condition, you better check, even if it means a few holes. Curiosity has nothing to do with it.
    At least, that's what I'd tell them. :)
    I closed the valve...
    Jamie Hall Member Posts: 27,379
    Good show. Now let us know who screams about what so we can find out what it did!
    ratiodelta T
