What do you consider the best way to heat a house?
What do you consider the best way to heat a house? 52 votes
Water boiler with cast iron radiatorsWould've voted for high efficiency boiler and micro zoned TRV'd low mass radiators (or low mass infloor heat).0
Naturally all choices would be selected assuming the highest efficiency furnace/boiler/heat pump.
I use wood as well, but I can't always be home to feed the fire.0 -
Steam boiler and cast iron radiatorsVapor vacuum steam system.
Nothing gives better balance, comfort and efficiency. Needs little too No electricity, very few moving parts, a long life expectancy, easy to maintain and I can heat a space the size of city block with one boiler.
What's more efficient?
Water boiler with radiant floorsI'm in no way a professional but if I was building from scratch I would do a water boiler with radiant floors. Probably even going to do staple up radiant under my kitchen floor because it's on the north side of my house and always seems cooler than the rest of the zone it's grouped with.1
Steam boiler and cast iron radiatorsMy issue with radiant in walls, ceilings and floors,especially concrete is it seems like everyone that posts even a minor issue wishes they were dead.
I mean, not literally but they seem awfully upset.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
2 -
Anything buried is a nightmare. Got 60' of concrete to break up when this other wet return goes. 30' of that return is through a studio. Going to be some s'plaining to do when that happens.0 -
Water boiler with radiant floorsHot water with radiant floors should have floors omitted . Ceilings are often a better option yet often overlooked and walls can be of use also .
732-751-1560
Rich McGrath 732-581-38331 -
Air quality is becoming a big concern in comfort systems, follow Robert Beans teachings
If you follow his reasoning then some air movement and treatment including humidity control would be part of the "best" systems.
Passive solar, radiant surfaces, with air side component as needed, would be on my list.Bob "hot rod" Rohr
Living the hydronic dream2 -
I'm really comfortable with my Rinnai gas direct vent wall furnace and mini-splits. Nice combination.0
Water boiler with radiant floorsI built from scratch in 2009, water and slab on grade radiant. 100% wood fired. Cast iron radiators for second floor. Would do it all the same again.
Just piped in Weil McLain ECO70 as backup heat, will figure out how well that works, all said and done max of 110 degree return water to mod-con.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0 -
Long term planning ......No heating expert here, but heard radiant plastic pipe was guaranteed for ~25 years...... what do you do after 25 -30 years, rip up the floor and replace the pipe??
I've got a 60 year old monflow with cast iron baseboards and I plan on living here at least another 30 years. dad was 99.5. Very happy with this system-1 -
> I've got a 60 year old monoflow with cast iron baseboards and I plan on living here at least another 30 years. dad was 99.5. Very happy with this system
Then please vote accordingly0 -
Forced air furnaceDepends upon the budget. In a new house where A/C is needed, budget wise you can get pretty decent comfort from a modulating forced air furnace and have the ducts for A/C. If money is no object, I'd want radiant floor and a duct system for a heat pump for quick, mild weather heating and cooling.0
While warrantys may be 25 - 30 years the tubing ( Pex-A ) has been through rigorous testing and is expected to last longer than 100+ years .Leonard said:Long term planning ......No heating expert here, but heard radiant plastic pipe was guaranteed for ~25 years...... what do you do after 25 -30 years, rip up the floor and replace the pipe??
I've got a 60 year old monflow with cast iron baseboards and I plan on living here at least another 30 years. dad was 99.5. Very happy with this systemYou didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38333 -
I am always leery of "new materials or tech" as well. And certainly if its in concrete it's gotta work or abandon it. Pex-a at least has been in use in low temp closed loop radiant systems for well over 40 years in Europe where it was origionally developed. It was designed to be embeded in concrete, with that track record I used it. Not the Chinese stuff that we have seen the problems with splitting (think Kitec).
But I have all soldered copper elsewhere, and install as such.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!1 -
What is the warranty on steel or copper pipe?Leonard said:Long term planning ......No heating expert here, but heard radiant plastic pipe was guaranteed for ~25 years...... what do you do after 25 -30 years, rip up the floor and replace the pipe??
I suspect plastics will outlast many copper or steel pipe systems, unless damaged or operated beyond the listing, pressure and temperature.
Living the hydronic dream1 -
My answer is not among your poll's choices.
Passive solar.0 -
Radiant woodstove.
Or masonry heater, i.e. Russian.0 -
Water Radiant ...
However, has anyone claimed warranty on pex?
Is it like everything else, where they use the warranty as a feature to sell product but then do everything they can to get out of it? Such as charging absurd shipping and not stocking parts so it takes weeks, or months to get?
Copper doesn't need a warranty, people know it outlasts most humans, if not several generations when used properly.
That said, I'd have no problem using pex a in my home. B and C not so much. In fact, I may be running some pex a in the near future.
But running hundreds of feet in a concrete floor scares me. No more than copper in that respect.
For my own preference, cast iron radiators with steam.
For people who "don't like ugly radiators" radiant of some sort.
Most of the reputable companies have zero issue honoring the warranty they offer . Only had to have it done once in 32 years now . However , contrary to your belief that copper is so superior , I have ripped out literally tons of copper tubing with pinholes eroded fittings and a plethora of other issues . A few of those times the copper as was told to me was warrantied and when we contacted the manufacturer the very first thing they wanted was a water sample . When sent , each time the Ph was wrong or there was a chemical issue . So there's your 50 year copper tube guarantee explainedChrisJ said:
For people who "don't like ugly radiators" radiant of some sort.You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38332 -
Steam boiler and cast iron radiatorsI was in Quebec when it was -20f and my friend was living in a house still underconstruction@ 75% done.
He had styrofoam block walls filled with insulation foem/cement and radiant floors. It was the best heating , built home i have ever seen. second: regular house with steam; below the nc/sc line, anything else.0 -
Water boiler with radiant floorsWhen you do not have nat gas I think GEOTHERMAL s best0
As public water suppliers continue to change treatment chemicals I suspect we will see more and more copper pin hole issues. Chloramines seem to be more and more common, now they are trying to figure out what to add to chloramine treatment to stop lead leaching from brass and copper pin holes.Rich said:
https://www.wwdmag.com/contaminants/chloramines-found-cause-leaks-copper-pipe-systems
How is Geo Thermal working out ... Seems expensive to install and run .Wells , condensers and Pumps running all the time ... Boiler back ups... I know it's just moving energy but the electric meter spins like crazy on the units that I have seen , do you have to invest another 100k for solar panels to off set ?
Water boiler with cast iron radiatorsI have a contractor friend who just built a place here in NH. He did radiant tubing slab on grade driven by Geo.
It does work. HUGE money up front.
Needed the rebate money to make it cost effective.... but that is a different section of the wall to talk about that.
The key is to find the best operating condition. If you could ideally heat the home with 90° SWT compared to 140° the numbers improve. Technology continues to improved and has in fact since this issue was published.
https://www.caleffi.com/sites/default/files/coll_attach_file/idronics_9_0.pdfBob "hot rod" Rohr
Steam boiler and cast iron radiatorsI voted for steam -- but this is really a much more complex question. For a new build anywhere south of 50 north -- that is all of the US and the actually populated part of Canada (!), I'd have to say passive or near passive solar. I have been involved in the construction of several such buildings (houses and a school cafeteria and a couple of others) in New England (which doesn't have that great a climate for solar) and they work. They don't even look funny. However, what they do need is really good architecture and engineering to take best advantage of the sun, some really good storage mass built in, terrific insulation, high efficiency air to air heat exchanges (sensible only, not latent -- we tried latent and trust me, it's a real pain) and, perhaps more important than anything, truly fanatical attention to detail during construction. The advantage comes in running and maintenance, of course, which is minimal. Do you get your money back (they do cost more)? Hard to say.
But that only works for new construction. I have yet to see a way to retrofit passive solar -- and even active solar is pretty dubious. For updating an older house, my own feeling is that one has to consider two aspects separately: the part of the system which moves heat around the structure and delivers it to the various spaces, and the part that generates the heat in the first place. As a sort of general thing, I'd be very wary of changing the moving delivery part, with the sole exception of changing from gravity to pumped hot water -- and even there I'd be cautious. I certainly wouldn't change steam to hot water, or vice versa, nor either one to forced air or vice versa. On the heat generator side, though, if cost is no object I'd surely take a look at geothermal source heat pumps, provided the heat moving system can operate at relatively low temperatures. I'd love to see more modulation available for residential steam boilers, but there -- and modulating condensing boilers for hot water and heat pumps in general -- again one has to look dispassionately at the original purchase costs, life, and ongoing maintenance costs relative to much simpler equipment to make an intelligent choice.Br. Jamie, osb
- 109 Chimneys & Flues
- 976 Plumbing
- 387 Solar
- 17 Recall Announcements
