I'm still waiting to walk in the door and see one properly piped. I Have seen worse.
Double D
Member Posts: 442
The original call was for a leak in a pipe over the boiler. It ended up being a pinhole in a dry return.
At first glance I mentioned to the homeowner that the boiler is not properly piped. Although I wasn't thinking she was doubting what I had to say, she let me know there was another serviceman there who never mentioned anything about the piping. Rather than see her spend more time and money for other opinions, I asked if it would be ok to post pictures of the install here to see what people that know what they're looking at have to say. I told her I would send her the link if I get any response.
1
Horrendous...New England SteamWorks
newenglandsteamworks.com0 -
I'm not sure what I like best -- the copper long horizontal in front of the sight glass which I suppose is meant to be a Hartford loop sort of thingy, or the equalizer (I think) fed off the leg of a T set vertically in the undersized copper "riser", or the ingenious use of the two separate riser connections to feed two separate mains, or...
Look. If even I can see that much that's unusual...
I might add, though, that if it provides reasonably quiet, even heat, it is an astonishing testimony to the ability of steam to work under adverse conditions!Br. Jamie, osb
Not much worth salvaging.0
****. That is so, so wrong.0
It may work somewhat, but at what cost in excess fuel consumption?
The pinhole leak probably provided the main venting!
I wonder why she didn’t call the other serviceman for the leak repair, and was he the installer?
He has made some good money on this, and wants to keep a low profile.—NBC0 -
Sick0
Send them the link, I usually try and say what's right, but I can't find anything on that one.
And a "professional" charged money for that.0 -
Looks like Beavis and Butt-head piped it. Tear out all that copper and start over.All Steamed Up, Inc.
Consulting3 -
@Steamhead I was thinking Larry, Curly, and Moe....0
Well one good thing is that it would be easy to cut out the copper and start over.0
1-1/4" into 2-1/2" I think it might be time to send the link. The mains are 2" but the risers out of the original boiler were 2-1/2". The system heats but not evenly and yes it hammers.0
Quality install on dwh with flex lines. I bet you can shake that line 6” in each direction.0
Well. At least they used both risers.0
Had to after cutting cross sectional area by 75%.STEAM DOCTOR said:Well. At least they used both risers.
Tape on the flue pipe0
https://www.youtube.com/watch?v=xXHVVXAcNYM1Matthias said:@Steamhead I was thinking Larry, Curly, and Moe....
Consulting3 -
@Steamhead Exactly.0
Ok, I'm going to say something positive...I like the flanges. Although the original might be flange unions I suppose.0
Bwahahaha! I rarely see steam boilers and I'm certainly not an expert, but any idiot can see that is not a proper, professional install.
It looks like a DIY job by someone who has never seen a steam boiler before. I'm surprised it functions.0 -
You haven't been around here very long have you? Other than people on this board, this is typical of what we see from contractors on steam. Well let's go with the low end of typical.SuperTech said:
Look at my profile picture, that's a DIY job by me.....
Just aweful... almost criminal. Installs like that rip off the customer and give steam a bad rap. I see these types of installs more often than I should. Couldn’t be piped any worse.0
The way I read the OP's post, I think the request is for a check list of each of the many things that are wrong with this installation.
I'm not the guy to do that, but I am sure others could supply this check list. Anybody want to chime in?
The first step in solving any problem is TO IDENTIFY THE PROBLEM.0 -
THATS AWESOME!! ok..now someone tell me what the black box is to the right of the tag..I'd try and identify it based on piping but my eye's crossed trying to follow it...0
I assume you are talking about the original pictures? If so, that's a probe type Low Water Cut-off.lchmb said:THATS AWESOME!! ok..now someone tell me what the black box is to the right of the tag..I'd try and identify it based on piping but my eye's crossed trying to follow it...
Artistic??Homeowner, Entrepreneur, Mechanic, Electrician,
"The toes you step on today are connected to the butt you'll have to kiss tomorrow". ---Vincent "Buddy" Cianci2
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
