Need to add BTU with as little hassle as possible.
pm124
Member Posts: 34
I have an oversized boiler and a cold top floor. That means more BTU! There are lots of local suppliers of steam radiators here. But it is possible to find 2 of the same height with plugs at the top, remove the plug, and connect them that way? It seems a lot easier than putting a T connection at the steam outlet, moving the existing radiator, repainting the wall behind the radiator, etc.
The problem is... where would the condensate go? So... no, not really.Br. Jamie, osb
Just an amateur here. But a few more details would help. Is the current rad getting hot? All the way across? Is it one pipe or two pipe? Is there room for a larger rad? Pictures are extremely helpful also.Homeowner, Entrepreneur, Mechanic, Electrician,
"The toes you step on today are connected to the butt you'll have to kiss tomorrow". ---Vincent "Buddy" Cianci0 -
Can you reduce the output of the 1st floor radiators? Otherwise could install a single larger radiator on the top floor?
Might be able to add a small fan and “boost” existing radiator on the top floor.0 -
I seriously doubt the size of your radiators is the issue. This sounds like a venting issue, but we need more details.New England SteamWorks
newenglandsteamworks.com0
