Need to add BTU with as little hassle as possible.
pm124
pm124 Member Posts: 34
I have an oversized boiler and a cold top floor. That means more BTU! There are lots of local suppliers of steam radiators here. But it is possible to find 2 of the same height with plugs at the top, remove the plug, and connect them that way? It seems a lot easier than putting a T connection at the steam outlet, moving the existing radiator, repainting the wall behind the radiator, etc.
    Jamie Hall Member Posts: 26,001
    The problem is... where would the condensate go? So... no, not really.
  • brandonf
    brandonf Member Posts: 208
    Just an amateur here. But a few more details would help. Is the current rad getting hot? All the way across? Is it one pipe or two pipe? Is there room for a larger rad? Pictures are extremely helpful also.
    Homeowner, Entrepreneur, Mechanic, Electrician,
    "The toes you step on today are connected to the butt you'll have to kiss tomorrow". ---Vincent "Buddy" Cianci
  • mikeg2015
    mikeg2015 Member Posts: 1,194
    Can you reduce the output of the 1st floor radiators? Otherwise could install a single larger radiator on the top floor?
    Might be able to add a small fan and “boost” existing radiator on the top floor.
  • New England SteamWorks
    New England SteamWorks Member Posts: 1,528
    I seriously doubt the size of your radiators is the issue. This sounds like a venting issue, but we need more details.
    newenglandsteamworks.com
