Goodbye Baseboard
Mike Cascio
Member Posts: 143
Last piece of slantfin removed from my one pipe steam system. The previous owner went on a modernizing spree in the 80's. The slantfin worked great while the boiler ran but got stone cold in 5 minutes after it stopped firing.
Found this american radiator wall rad across the street in the trash. Unfortunately it was three sections long. I seperated it, cleaned up and finally got it in. Still need to find some better wall brackets.
4
You must have a better garbage pickup than we have, as we are restricted to 35 pounds a can!—NBC0
Nice find and nice job!!0
@MikeCascio that Rad does look good.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......0 -
Great move....if you feel it’s a bit oversized or you want regulation,install a thermostatic vent..0
Great find.
I have 2 of those radiator. Great heat output but minimal footprint. 1 have a single section in a little 15 sqft bathroom closet with a TRV. And a 2x4 array in a foyer hallway near an outside door. I think the vent is in the wrong spot. The dead men made a few mistakes sometimes.0 -
Where can I find some decent brackets for this rad?0
If you can't find them - you can fashion some out of a good lag bolt into a stud and a piece of rectangle steel with a hole in the middle that you can probably get any machine or welding shop to make you for cheap. 3 points of contact, 2 under the rad sides, one in at the top middle between the ribs. Then paint the same color as the radiator.Mike Cascio said:Where can I find some decent brackets for this rad?
Man, that's a nice radiator...0 -
Yes, I kinda think it was the later generation dead men, that were not as skilled....I have seen some really piss poor work by the original installers.mikeg2015 said:Great find.
http://ocsind.com/wp-content/uploads/2017/02/15981-OCS-Catalog.Updated15.pdfAll Steamed Up, Inc.
Consulting0 -
Mike, Why would your copper fin baseboard go stone cold, just because the boiler turned off.
Does your pump run constantly?
Does your boiler control provide outdoor reset control?
PaulSince 1990, I have made steam systems quiet, comfortable, and efficient. We provide comfort while saving the planet.
NYC RETROFIT ACCELERATOR QUALIFIED SERVICE PROVIDER
A REAL GOOD PLUMBER, INC
NYC LMP: 1307
O:212-505-1837
M:917-939-05930 -
Mike,
DAAA! I just noticed you said one pipe steam.
paulSince 1990, I have made steam systems quiet, comfortable, and efficient. We provide comfort while saving the planet.
NYC LMP: 1307
O:212-505-1837
M:917-939-05930
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
