Goodbye Baseboard
Last piece of slantfin removed from my one pipe steam system. The previous owner went on a modernizing spree in the 80's. The slantfin worked great while the boiler ran but got stone cold in 5 minutes after it stopped firing.
Found this american radiator wall rad across the street in the trash. Unfortunately it was three sections long. I seperated it, cleaned up and finally got it in. Still need to find some better wall brackets.
MilanDkcoppnjtommyCanucker
  • GW
    GW Member Posts: 5,136
    Much better way to go
    Gary Wilson
    Wilson Services, Inc
    Northampton, MA
    gary@wilsonph.com
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,578
    You must have a better garbage pickup than we have, as we are restricted to 35 pounds a can!—NBC
  • MilanD
    MilanD Member Posts: 1,162
    Nice find and nice job!!
  • Dave0176
    Dave0176 Member Posts: 1,178
    edited January 2018
    @MikeCascio that Rad does look good.
    DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
    NJ Master HVACR Lic# 4630
    I cannot force people to spend money, I can only suggest how to spend it wisely.......
  • BobC
    BobC Member Posts: 5,539
    How many men did it take to move a 3 section assembly like that?
    Bob
    3PSI gauge
    j a_2MilanD
  • j a_2
    j a_2 Member Posts: 1,804
    Great move....if you feel it’s a bit oversized or you want regulation,install a thermostatic vent..
  • mikeg2015
    mikeg2015 Member Posts: 1,194
    Great find.
    I have 2 of those radiator. Great heat output but minimal footprint. 1 have a single section in a little 15 sqft bathroom closet with a TRV. And a 2x4 array in a foyer hallway near an outside door. I think the vent is in the wrong spot. The dead men made a few mistakes sometimes.
  • Mike Cascio
    Mike Cascio Member Posts: 143
    I moved the three section assembly myself, it wasnt easy. A lot of sliding and dragging. Im going to put a slower vent in, the gorton 6 is way too fast for it.
    MilanD
  • Mike Cascio
    Where can I find some decent brackets for this rad?
  • MilanD
    If you can't find them - you can fashion some out of a good lag bolt into a stud and a piece of rectangle steel with a hole in the middle that you can probably get any machine or welding shop to make you for cheap. 3 points of contact, 2 under the rad sides, one in at the top middle between the ribs. Then paint the same color as the radiator.
    Man, that's a nice radiator...
  • j a_2
    mikeg2015 said:
    Great find.
    Yes, I kinda think it was the later generation dead men, that were not as skilled....I have seen some really piss poor work by the original installers.
    Steamhead Member Posts: 18,192
    OCS Industries makes nice ones. Go to page 5 of the catalog:
    http://ocsind.com/wp-content/uploads/2017/02/15981-OCS-Catalog.Updated15.pdf
    Consulting
  • Paul_11
    Paul_11 Member Posts: 210
    Mike, Why would your copper fin baseboard go stone cold, just because the boiler turned off.
    Does your pump run constantly?
    Does your boiler control provide outdoor reset control?
    Paul
    Since 1990, I have made steam systems quiet, comfortable, and efficient. We provide comfort while saving the planet.
    NYC RETROFIT ACCELERATOR QUALIFIED SERVICE PROVIDER
    A REAL GOOD PLUMBER, INC
    NYC LMP: 1307
    O:212-505-1837
    M:917-939-0593
  • Paul_11
    Mike,
    DAAA! I just noticed you said one pipe steam.
    paul
    NYC LMP: 1307
    O:212-505-1837
    M:917-939-0593
