A question for the professional heat installers
I know my company has techs, but not sure how well they are trained. I fixed my boiler after he couldn’t figure it out and I barely know anything about heating systems. I will give them a call, maybe they know someone.0
Where are you located and why do you think your boiler will fail soon?
Sometimes the small time guy who doesn't advertise doesn't have to, they have plenty of work that they want.
.......Or they don't know they should.0 -
Hi, Hope I'm not being too obvious, but have you tried clicking on the button at the top of the page called find a contractor?
Yours, Larry0 -
What kind of system have you got ?Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
Where in VT?0
I have, no one comes upLarry Weingarten said:Hi, Hope I'm not being too obvious, but have you tried clicking on the button at the top of the page called find a contractor?
Yours, Larry0 -
Here you go Gordy. I have been maintaining it myself fir a long while. Possible leak in boiler, fan is corroded from inhaling exhaust. How do you like the indirect tank tucked in the corner? Can’t replace the safety valve because it is so tight to the wall. Drips when water heats up because there is no expansion tank on the water line.Gordy said:Maybe some pics of the system, a discription, and the ability to provide more information as asked for will certainly lend you a couch for analysis here. If anything to educate yourself enough to weed out the unworthy.
I'm not a professional installer, not am I in Vermont any more. However, Vermont is where I learned the trade, decades ago. It was then, and still is, a difficult place to find really qualified people. They are out there, but the really good ones are really busy and tend to have long time client relationships. They are small -- often one man shops, or a family -- and honestly they don't need to advertise.
Your best bet may be your oil delivery company, assuming that you have an ongoing relationship with them.Br. Jamie, osb
I agree that the fuel company would be a good place to start. Your local.supply house may be another good resource.0
Rutland is just to the north.
30 miles.
I would look there.
I can get names as I have family there still.
What type of emitters?
I don’t know the technical terminology. Emitter? I know how to ckean it. Ohm out bad sensors. The water end is what I don’t know. I’m not even sure how to fill it back up if I have to drain it. I also think it’s to big. 3100 square feet. 117 feet of copper fin. GB142. 60Gordy said:What type of emitters?
Radiant heat
Cast iron radiators
Baseboard
And it's split into 5 zones!Gordy said:Well that’s a nice match. 168 k output to 60k of radiation.....
Does the house heat as desired?
What are the water temps supplied to the radiation?
No wonder the boiler has issues: it's short cycled itself to death.
Bob Boan
Call Buderus . They are in Londonderry , NH . They may have the name of someone to nurse it through till spring . You may have to contact someone in NH , Mass or NY .
In the spring I would look to replace with something of the Stainless Steel species and get rid of the Aluminum .
Perform a room by room heat loss calc in the meantime to get the ball rolling .
A nice HTP UFT boiler comes to mind . You could possibly need a unit up to 120k but I would suspect a 100 or 80 would more than likely be sufficient for your size house even if it is of poor construction ( air sealing , R value) .You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
Still "cleaning up" after the long extended cold spell. We haven't had one like that in a while. People have gotten lazy and let their systems and infrastructure go slack. If there are weak spots in your actual hardware and your management/maintenance thereof--the cold will find you out!
I have a pretty large customer base in a small area. One man show. Hard to keep up. Everything from limping systems to whole house freeze-ups. New installs in middle of "the season."
Crazy.
Manchester is a "ski area." No hydronics guys? Then Rutland is your best bet.0 -
117 feet of fin tube baseboard radiators, they probably don't emit more than 60K or 70K BTUs. Unless you add more radiators/baseboards, you don't need a boiler larger than what the radiation can put out.Hydronics inspired homeowner with self-designed high efficiency low temperature baseboard system and professionally installed mod-con boiler with indirect DHW. My system design thread: http://forum.heatinghelp.com/discussion/154385
System Photo: https://us.v-cdn.net/5021738/uploads/FileUpload/79/451e1f19a1e5b345e0951fbe1ff6ca.jpg0 -
In real cold I believe it is 180. The house heats well. Insulated pretty good. Good windows. Most if the attic space is in the r60 rangeGordy said:Well that’s a nice match. 168 k output to 60k of radiation.....
What are the water temps supplied to the radiation?0 -
Just found another leak . Revision vent. Going to have to order one.0
At 180f it’s no more efficient than a cast iron boiler that’s cheaper and lasts 2x longer with fewer parts. Water temps need to be under 150f supply to start to gain Effeciency. Small zones are less of an issue too with a CI boiler since they have some water capacity to work with. Only moving part is the flue damper and you can bypass that in open position if needed I’m an emergency.
That thing is massively oversized. Probably why your wearing out so many parts.
Time to look at downsizing and replacing it next season. If heat loss is 60k you want a 70-90k input boiler depending on water temps. But your h at loss is probably even smaller.-1 -
Can something like that be direct vented?mikeg2015 said:At 180f it’s no more efficient than a cast iron boiler that’s cheaper and lasts 2x longer with fewer parts. Water temps need to be under 150f supply to start to gain Effeciency. Small zones are less of an issue too with a CI boiler since they have some water capacity to work with. Only moving part is the flue damper and you can bypass that in open position if needed I’m an emergency.
Time to look at downsizing and replacing it next season. If heat loss is 60k you want a 70-90k input boiler depending on water temps. But your h at loss is probably even smaller.0 -
I still have mine -- haven't used it in years. But I was up recently to visit some and talking with some of the folks, and they tell me it ain't like it used to be. Particularly in the ski areas and around Burlington/Middlebury/Bennington. Not the same people at all...lchmb said:maybe I should renew my Vt license..
Plenty of different options on the market..but in your case I would be looking for service/parts available. So you really need to find the right local person/company and work with them. You can of course bring the info here and we can work with you to get the best bang for your buck... good luck...-1
- 76 Pipe Deterioration
