Prestige Triangle Tube Doesn't Produce Heat for Room
fivepointer
Member Posts: 9
Hi,
I have a Prestige Triangle Tube (2010-46 Prestige User's Manual) that has not worked in over a year. Unit is still pretty new at <8 years old, I believe. We have 3 different stages in our home: one downstairs where the hot water heater is located, and the other two on the main level. Unsure if its failure to heat is related to a power outage we had where I recall the pump turning off and my kids keeping the bathtub water going until it was pumping brownish water.
Anyway, hot water in faucets and tub/shower works great. Propane is full and breakers all checked. I've tried resetting the machine and adjusting thermostats but the heat never kicks on in any of the units and I get a 6180 (i.e. "burner off due to reaching temperature setpoint"). Should I bite the bullet and call out a plumber or might this be an easy fix? Happy to supply photos if helpful.
Hi Tom,
I live in northern Vermont. I'm pretty sure the circulator is good. It is a Grundfos alpha 15-55f. When I adjust the thermostat in the basement the panel that has the lights showing the heating zones lights up and the circulator has a display that works and shows activity. All pipes near the unit are cold to the touch.0 -
You most likely have a bad diverter valve. That system needs a mag. type dirt filter to keep stuff out of the DV.0
Is this a solo or excellence? Do the hot and cold domestic water lines connect to the boiler or a stand alone tank?0
Hi,
Solo. Water lines connect to the boiler.0 -
I can't help but ask: does your handle relate to your theological position?Bob Boan
What size is it?
Can you post some pics?Bob Boan
Boiler pics. I haven't seen a ton of them myself, but my wife seems to think it does the job...
That's a Prestigue Excellence.
There's a 3 way motorized valve inside that diverts all the heat to the internal indirect when it calls for domestic. For some reason, the valve is not shifting to space heating once the domestic call is satisfied. It could be the actuator on the valve or the indirect's sensor.
I'm not sure on the old model, but I believe there should be a time override on domestic priority. If you have the I/O manual, it should tell you.Bob Boan
Is this what you're referencing?
Yes, parameter 43.Bob Boan
My moneys on the diverter valve, you really should have a dirt-mag separater on that boiler.0
unclejohn,
You may be right, but this house had a big woodstove when I was there last. The previous owners use to crank it up, and the finished basement kept the first floor pipes from getting any heat and under the porch out front it froze often,
It hit -30 here around the same time this post was started. I would check there first.Tom
Montpelier Vt0 -
Tom I will defer to your previous experience, but rest assure I never wager more then a dollar.0
Hi Tom,
That's crazy-- what a coincidence! We do have a wood stove, though I wouldn't describe it as big. What would you suggest I do? I haven't yet tested the parameter 43 setting. When you say its frozen do you mean one of the pipes, and if so is it likely that it would be that way both last season and this season?0 -
Most likely, the heat zone for the first floor runs under the front door and between dining and living room I believe, thats where it typically froze in the past. I usually stopped in said hello to Mike the previous owner clamped on my Hotshot pipe thawing machine and in 30 mins or less I was gone.Tom
Montpelier Vt0 -
I wonder... @Tom, did you happen to know either Bob Hood or Tom Mahar? Worked for the State years ago (like 40) as inspectors. They're the guys who taught me the trade.Br. Jamie, osb
I don't, but to be fair I just turned 40 and cant remember names to save my life. For some reason I can remember the orifice size on a gas dryer conversion from 10 years ago but no names. I associate everyone with the car they drive. With out that I am in big trouble.
Also please dont hold the wiring in pics against me, I went there to thaw pipes.Tom
Montpelier Vt0 -
Hi Tom,
Thanks for all the tips. I sent you a message.
James0 -
James,
I didn't receive anything, sadly there are more than one Tom on this site. I need to change my handle to TomVTTom
Montpelier Vt0 -
Tom,
Is your business called On Time Mechanical? I'd like to give you a call to discuss further!
James0 -
Yes sir thats me.Tom
Montpelier Vt0 -
My boiler is sending water to the external water heater for hot water in shower, dishwasher, etc. However, it keeps recycling and won’t send heat to the 4 units in building for heat.0
Power goes off on it when it recycles on the Taco controller. Always has0
Well, then that is a "thing". No power to the Taco= no heat to the zone.0
when it is sending hot water to the units the Taco Controller comes on. We have had this unit for 6 years and i have always wondered why when it "recycles" the taco powers off. When it goes back to 3150 and sends hot water, it comes back on. So you are telling me that the taco power light should never go off?
The guys that put this in told me that when it recycles it goes off.
Interesting right?
Not sure why they wired it that way. The boiler itself will control who gets the hot water domestic or radiant. So there should be no reason to power off that controller. Don't know how he is controlling the taco control box. But sounds like however it was controlled has now failed.
D0 -
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
