Fluke, need some advice
GW
Member Posts: 5,135
I lost (for the moment) my Fluke multimeter that could utilize this clamp on set up.
I can't get the clamp on set up to work with this Fluke
Do I need another Fluke (like the one I lost), or should this set up work? It won't show temp no matter what setting or button i push; it's got a new 9v battery too.
Thanks, Gary
Thanks, Gary
Or any meter that has the "K" terminal connection.
I have a $50 Field Peice DMM that I've had for years that I plug my Fluke clamp directly into. Works great.
Other than wanting to sell another component, IDK why Fluke won't offer the direct "K" connection on their meters.Bob Boan
thanks, that set up i have 'should' work; it certainly fits. I just don't know if i have some sort of compatibility issue or if my 80TH stopped working. I need a guy with vast multi meter knowledge to chime in!
I may just by a cheap Fieldpiece unit to get me through. When you need a clamp on, you really need it!0 -
I ordered this form the local vendor
https://www.amazon.com/hilmor-Dual-Readout-Thermometer-1839106/dp/B00FMFM272
Costs more but hey whatever
If anyone has any input on my existing fluke set up please let me know0 -
Hilmore's good stuff.
Bob Boan
well after i ordered the new clamp on thermometer i found my missing Fluke, of well. I don't know why this Fluke works with the k couple adapter and the other Fluke doesn't
It may have been the scale you set it to. Something in the back of my mind says that you have to use something other than the temp scale.Bob Boan
Yes the fluke 16 works in DC scale. The Fluke 324 I tried all sorts of settings, zip. I need to chat with a multimeter geek0
Ah. Were you, perchance, using the temp scale on the 324? The 80TK is a K-type thermocouple temperature-to-volt adapter. You'd need to use the DC volt scale, then it'd be one volt per ° F (or C if, you know, metric). Since the 324 has a temp scale, I'd imagine that you could use one of these as well, but the 80TK will work on any meter with a DCV scale that you could plug the adapter in to.0
Ok thanks I’ll try again for basic curiosity. I thought I did that but I’ll try again0
Flukes thermometers are great thermometers
Flukes DMM's are horrible thermometers
Fluke told me that after complaining about the inaccuracies of 2 #16's and 2 # 116's ive owned. i now have a very accurate albeit expensive #54 thermometer
JMHO0 -
When I'm looking for accuracy, I use my Fluke 724 temperature calibrator...
It'll read or simulate a dozen kinds of thermocouples and a handful of RTD sensors. Sometimes it's nice to be able to fool the controls, to see what it's going to do. If it did the high-resistance thermisitors (like 10 & 20 kΩ) it'd be perfect.
my new Hilmore is 1 or 2 degrees off (two clamps, same pipe). Oh well. I don't require super accuracy, often times i just need a basic contract.0
Yah, if you read the specs, most consumer-grade temp stuff is only good for ±2°—I'm always
violently angryamused when customers complain that the thermostat and thermometer right beside it don't agree to 1000 PPM.I truly think the industry as a whole would be well served to go to an arbitrary scale of say "A, B, C, D" on thermostats.
@GW The problem you may be having is the meter you tried to use doesn't have a low enough DC volts scale. I have one of those Fluke temperature probes and it works fine with all my digital multimeters (Fluke 8060's, 8100, and a 75).
On some autoranging meters you have to manually nudge the meter into the lowest scale where it would work with that Fluke temp probe.
3PSI gauge0 -
