Timber!
kcopp
Member Posts: 4,575
Here is a first. Pretty scary stuff. NOT my install but I have done some work for them. They hear a crash in the middle of the night and go down and find this .... thank God no one was hurt..... Yikes!
Crazy thing is that the copper piping attached only crimped. Very little water came out...maybe a gallon. The gas piping was done all in CSST so that flexed fine. Furthermore the thing was still turned on and running when I got there....0
The big guy up above, likes them. Wow.0
oops. Definitely oops. I'm not impressed by the anchors that were supposed to be holding it!Br. Jamie, osb
Glad no one was hurt. foundation walls that are below ground get damp, they just do. Add the paint and water vapor has a hard time escaping. The anchors used look like the rotted away then snapped. Probably not exterior grade anchors.
A wet foundation wall will rot screws like that in a year. I'd use stainless steel wedge anchors instead.2 -
those look like way-too-short cut masonry nails0
Wow! And it was still running! Nice.
I think it's time we reevaluated our concrete anchor decision making paradigm.......Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0 -
Him fall down!Bob Boan
It hung on the wall for 7 years. I generally build a wall and then attach the boiler to that. I was always paranoid about that happening.
This home has two of these. (long story) The other one attached the same way.... both are going to come out shortly.0 -
Here is a "what are they thinking!"...
The insurance company wants me to put the boiler back on the wall and "fix" it....
I explained to the lady that I am liable if anything ever goes wrong now.... I'm not having anything to do w/ that.0 -
I should also tell them that for me to install it I need a letter stating my waiver of any responsibility if anything should go wrong.0
- 110 Chimneys & Flues
- 981 Plumbing
- 387 Solar
