Steamer in progress!
Danny Scully
Member Posts: 1,424
Nice... that's one for the museum0
my parents have the same set up? the question I have is how does the steam get up, except for the banging in the morning everything is fine.0
I wish they still made that type of gauge. Maybe the name on this one describes whoever decided to stop making them....Danny Scully said:Add to the collection!
Consulting1 -
Lol, I get it0
Looking good @Danny Scully question I know New Yorker used to be rebadged Burnhams but that looks offaly like a Crown Bermuda?DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......0 -
I wasn't aware that 30 psi was full retard. Learn something new everyday.Danny Scully said:Add to the collection!
You can have it good, fast or cheap. Pick two1 -
No burner were they still burning coal?? Or using something else for heat besides the old boiler??0
@Dave0176, Burnham/New Yorker/crown/force are all the same.0
Aww, another long lasting Redflash getting replaced by a disposable boiler.
Nothing against you @Danny Scully I know you'll do a great job with what you can get. Just a shame we can't have new boilers built similar. Maybe with a little less water, but good heavy quality iron and 3 pass.Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment1 -
New England SteamWorks
newenglandsteamworks.com0 -
Danny Scully said:
Header prepiped. Now it’s lunch time!
Awfully fast work there @Danny Scully... Umhhh
But nice as always.New England SteamWorks
Well we just fired her up @New England SteamWorks, it’s alive!4
Quick skim before we go home!0
nice job @Danny ScullyASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company-1 -
You showed us yours, so I'll show you mine. (ARCO pressure gauge)
At some point in the past, someone used a grease pencil on the gauge glass to indicate a threshold point. However, the glass is held against the housing with springs and is able to rotate, so we'll never know what the setpoint was.
Also of note, the wire seen at ~7psi is part of a spring intended to put force on the needle as it rides all the way to 30psi. Chilling.
For other historical interest, this particular boiler has the mounting for a "Shur-Stop" fire grenade directly above the boiler doors, and ash scraper hanging from the ceiling from it's coal days.
Interesting. Is that what the "retard" range on refrigeration gauges means? There's a spring inside to greatly increase the range at the end?Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0
Nice job, Mr. Scully.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
