Off topic = Gas BBQ burner
2»
  • j a_2
    j a_2 Member Posts: 1,804
    ChrisJ said:
    Suzook said:
    Oh, That's a strange arangement. Mine is different. Probably too much pressure. Pushing more gas at the end???
    JUGHNE said:
    That would be my guess....lower the pressure with reg.
    That's the thing though.
    They rated it for 7" WC, and I'm at 6.5" WC. If I lower the pressure I'll have less heat overall and I don't want that either.
    Speaking of that, in low and dirty gas areas such as a lot of areas around Boston. it gets prey ugly when installers install appliances with a minimum pressure rating than what is delivered at the property, as well gas company only guarantees a pressure just under 5 in. W/C...Wind certinaly has an effect on performance of outdoor grills...Why cook outdoors with natural gas? Most people like it for the flavoring, I still use charcoal...Wish I could afford the Green Egg..But I can't .....
  • ChrisJ
    ChrisJ Member Posts: 17,052
    edited August 2017
    Why not?
    BTW, my wife hates the smokey taste of charcoal. I can get away with using lump charcoal, but never Kingsford with her. She says it tastes like burning tires.
  • ratio
    ratio Member Posts: 4,175
    Maybe you're using too much Boy Scout juice? ;)
    It's a common flavor during the summer months around here unfortunately.
  • ChrisJ
    Chimney only, no lighter fluid.
    I usually put a wad of new paper, or even paper towels in the bottom and light'r up.
  • KC_Jones
    KC_Jones Member Posts: 5,907
    If anyone has ever used a chimney starter they will forget about the existence of lighter fluid. The chimney starter is truly wonderful.
    2014 Weil Mclain EG-40
    ChrisJrick in Alaska
  • ChrisJ
  • ratio
    Exactly. You know it's done when you can nearly see a tongue of flame coming out the top.
